DG8401W Kernel panic
Gascousers
Message 6 of 6
My DG8041w router keeps randomly resetting. I have had line tested, engineer visits, etc. Wasted efforts. Looked at the user log and identified its Kernel Panic. After searching the forum I understand a firmware update fixes it. Is this correct and how do i get it.
Many thanks for any assistance.
5 REPLIES 5
Message 1 of 6
Gascousers
Message 2 of 6
Thank you Debbie, will do. Great service.
Message 3 of 6
Hi Gascousers
Apologies for this.
I've just made a change to your router firmware. Please can you monitor the connection and let us know how it compares.
Message 4 of 6
Many thanks Keith, appreciate the help. Just went down again as I was posting my thanks
Message 5 of 6
I will ask the TalkTalk support on this forum to update it for you.
