Faulty router
Steve004
Message 3 of 3
My router keeps dropping out and the only way to get it back on is to restart it, the light on the router doesn’t change when it drops out. I spent an hour on the tech support chat last week and I was told that it was now fixed but it is still dropping out for no reason, I would appreciate if you could send me a new router as I believe that is the problem.
Message 1 of 3
Line tests are showing a Battery fault out to Line.
I've logged this out to Openreach for investigation.
Message 2 of 3
This may not be the router at all, but the fix would be dependent on knowing the answers to these two questions:-
2. If you have any wired connections, are they affected in the same way as wireless ones?
