Forbidden 403 error
markgwhite19
Message 11 of 11
When I try to connect to certain websites using a browser or their app I am receiving a forbidden 403 error. If I use mobile data it's fine, use a friend's WiFi and it's fine. Just doesn't work on my WiFi. I've done a full router reset and no joy. Most sites work fine but some don't. Mainly topcashback. Any thoughts please?
10 REPLIES 10
Message 1 of 11
Hi @markgwhite19 glad that worked for you tbh no idea based on fact why it worked, but something possibly flushed something else.
Message 2 of 11
Hi mark,
Ok no problem. If anything does change then please let us know.
markgwhite19
Message 3 of 11
Everything seems ok now I've changed the dns setting and then put then back to auto. I'll see how it goes thanks.
Message 4 of 11
Hi mark,
Ok thanks for checking this. Would you like us to send a replacement router for testing purposes to see how this compares and to rule this out?
markgwhite19
Message 5 of 11
I did have a look at that yes. Nothing was turned on at the time. Thanks 😊
Message 6 of 11
Have you checked the HomeSafe settings in My Account to see if anything is showing as active?
markgwhite19
Message 7 of 11
Just tried adding manual dns and it's working 😊 I used 79.79.79.81. Any idea why the auto setting would stop working?
Message 8 of 11
Hi @markgwhite19 sorry I misread some of the info in your post.
Have you tried using a different dns?
Last suggestion till the TT staff are back in tomorrow 🤔
markgwhite19
Message 9 of 11
Yes, tried powering router off/on tried full router reset, tried a different browser, tried different devices. Same result.
Divsec
Message 10 of 11
Hi @markgwhite19 have you tried rebooting your router and a different browser?
your post has been escalated and you should hear soon.  In the meantime please check your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
