No internet connection over a week
AyanHassan
Message 3 of 3
I am writing to express my dissatisfaction with the ongoing service disruption I have been experiencing. I have had no connection for over a week, and as someone who works from home, this has been particularly detrimental. While I understand that other customers are facing similar issues, the lack of resolution is unacceptable, and I feel it is necessary to take further action.
Chris-TalkTalk
Message 1 of 3
Hi Ayan,
If you have been experiencing the disconnections with white light staying on then can you reboot your router and check to see if the problem continues
Message 2 of 3
Are you affected by this issue, if so it is expected to be OK by tomorrow morning:-
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
