Openreach modem led died
Divad3
Message 14 of 14
One of the leds on my Openreach modem has stopped working. It’s the internet one. Does the modem need replacing?
13 REPLIES 13
Message 1 of 14
You're Welcome 🙂
Divad3
Message 2 of 14
Many thanks
Message 3 of 14
OK, I'll make sure it is the Modem that is sent.
Divad3
Message 4 of 14
Yes it is the modem that has a fault.
Message 5 of 14
The router that was ordered was a talktalk router - is it the Modem that is at fault ?
Divad3
Message 6 of 14
At the moment I have a TalkTalk router that is plugged into a by Openreach modem to support my broadband speed of 150meg
willthis replace the modem portion of my set up?
Message 7 of 14
A router has been ordered for you.
Divad3
Message 8 of 14
Yes please, that would be great.
thanks
Message 9 of 14
It will be a Sagemcom, would you like me to arrange to send one?
Divad3
Message 10 of 14
That would be great thanks.
What model would you send out?
Message 11 of 14
I think the broken led is unlikely to be and indication that there are any other issues with the router but we can send a replacement if you like but it won't be the same make/model
Divad3
Message 12 of 14
Thanks for replying to my query.
At the moment it only appears that the led has died but I am concerned that it could cause other issues and don’t know if there are other problems inside the modem.
Chris-TalkTalk
Message 13 of 14
Hi Divad3,
Are you experiencing any problems with your service or is it just the LED that isn't working?
