Router Firmware Update
Clarence
Message 146 of 146
Sometime ago I purchased a new Fast 5364 router from TalkTalk.
I later purchased a BT Premium Whole Home Wi-Fi system with a Pack of 3 Discs which worked fine with the router.
Then, following a firmware update, the discs would no longer connect to the router. I contacted BT who said they were aware of the issue and I should contact TalkTalk, which I did. However, TalkTalk was unable to help and I reverted back to an old router, which did work with the discs.
I now understand that TalkTalk has resolved the firmware issue and there is a new version which will work with the discs.
If I leave the Fast 5364 router plugged in overnight, will it automatically be updated to the latest firmware version?
145 REPLIES 145
Message 1 of 146
Hi Clarence,
I'm sorry to hear that but thanks for letting us know.
Clarence
Message 2 of 146
So I reinstalled the Sagemcom router at 4.30pm on the 29th November and it disconnected today about 5pm so 2 days uptime and then off as before.
It didn't reconnect automatically and so I've now reinstalled the BT router again.
Shame we couldn't get the Sagemcom working properly but thanks for all your help.
I'll send it back to you.
Message 3 of 146
OK thanks, please let us know how you get on
Clarence
Message 4 of 146
I replaced the Sagemcom after it disconnected on Thursday with the BT router because we have intensive zoom meetings all this week and I can't risk another disconnection at the moment. I'll try it again next week but to be honest I don't hold out much hope.
Message 5 of 146
How has it been since over the weekend? When was the last time the connection dropped?
Clarence
Message 6 of 146
I have to reboot it Chris.
The only possibe reason I can think of for this phenomenon is that I am using BT premium whole home discs for my wifi.
If you check my first post you can see there was a problem following a previous router firmware update, where the router wouldn't work with the discs at all.
The current firmware version does allow the discs to work but now we have this disconnection problem every 2 days. Why it should be every 2 days is anyone's guess. Perhaps the firmware has a mechanism for making a check every 48 hours and resets if it finds something it doesn't like?
Message 7 of 146
Hi Clarence,
Does the router reconnect by itself after it disconnects or do you have to reboot it?
Clarence
Message 8 of 146
Hi Karl
The router disconnected today so I have replaced it with my BT router which works without issue.
Really don't know what the problem could be with the Sagemcom router. The ones I've tried just seem to work for 2 days and then disconnect whereas the BT router and my old Huawei router work fine.
Did @KeithFrench get back to you with any similar issues he'd come across?
Message 9 of 146
No Problem 🙂
Clarence
Message 10 of 146
Yes. Thank you so much Karl.
Just hope this router doesn't keep disconnecting every two days like the last one.
Fingers crossed.
Message 11 of 146
Router now showing on FW 206.
Message 12 of 146
Firmware pushing now 🙂
Clarence
Message 13 of 146
Hi Chris
I have just installed the new TalkTalk router you sent me.
Please would it be possible to push down the latest firmware update?
Message 14 of 146
Clarence
Message 15 of 146
Thank you Chris. Much appreciated.
Fingers crossed!
Message 16 of 146
I've ordered the router, it should be with you within a couple of working days
Message 17 of 146
It probably won't come with the latest firmware installed, it usually automatically updates within 48 hours of connecting it
Clarence
Message 18 of 146
Hi Chris
That's very kind of you.
Can it come with the latest firmware already installed?
Message 19 of 146
Hi Clarence,
Would you like us to send another router to test with. I don't know if it will fix the problem but it will at least rule out a hardware fault with the current router
Clarence
Message 20 of 146
