4 hours ago - last edited 4 hours ago
Hello there. Whenever I try to manually set channels on my Sagecom Router to avoid interference from neighbours, after a day or so, they switch back!
This is completely unacceptable as the router always seems to find the most congested channels on both 2.4 and 5Ghz bands, you couldn't ask it to find worse channels if you tried!
I beleive this problem is unique to the Sagecom router and is down to a feature called 'Wi-Fi Optimisation' which needs to be switched off remotely by yourselves.
Please could you do this for me as soon as is humanly possible, I'm at the end of my tether with poor Wi-Fi reception at even 2-3 Metres from the modem on some days.
Many thanks in advance.
3 hours ago
Hi @CeeBee2001
My colleague in the faults escalation team has advised that they have contacted you this morning.
3 hours ago
3 hours ago
Many thanks, Debbie!
3 hours ago
Hi @CeeBee2001
I've passed this over to the team now and asked them to make contact as soon as possible so they can discuss this with you.
3 hours ago
That would be fantastic, thanks, Debbie, have a great day!
3 hours ago
Hi @CeeBee2001
I can pass this to our faults escalation team so they can discuss this with you. Would you like me to arrange this?
3 hours ago - last edited 3 hours ago
Hi Debbie. Running these checks won't change anything other than taking up our valuable time. I've clearly stated the issue, I need the ability to manually set Wi-Fi channels on my Router.
A booster would be of no use at all, it would only likely increase congestion and interference for others in the building. I'm only 2-3 metres from the modem with most of my Wi-Fi equipment.
3 hours ago
Hi @CeeBee2001
Would it be ok to run through a few WIFI checks, we can also send a WIFI booster to help with coverage issues.
That's fine, Debbie, not your fault. I just need to know how we move forwards from this. As far as I can see, the only viable solution is to send me a router that doesn't have this so-called 'Wi-Fi optimisation'. Could you look into this for me please?
3 hours ago
Hi CeeBee2001
I'm really sorry about this. It was a business decision to no longer switch off WIFI optimisation.
4 hours ago
I just need the ability to change channels. When I have changed them to non congested channels in the past (for a day or so), the problem is resolved, every single time.
I should also add that I'm an ex-commercial Wi-Fi installation engineer so I'm more than familiar with channels, congestion and RF.
I run WiFiman scans regularly that confirm that there is a congestion issue due to my router automatically hopping on to the most congested channels.
4 hours ago
4 hours ago
Hi @CeeBee2001
I can see that @Debbie-TalkTalk has stated TalkTalk's position on WiFi Optimisation. While I am not defending this decision, I often find cases where the cause is actually something else.
Hi Debbie, thanks for the info. Could you arrange send me a router on which I can manually select channels then, please?
I know exactly what is causing the interference, it the fact that most people in my block of flats are on Channel 1 (2.4Ghz) and Channel 40 (5Ghz) These are the channels that my Sagecom router seems to love to jump on hehe. It's quite the chocolate teapot!
I await Keith's advice but I'm not sure anything he can say will help with this particular issue, to be fair. I remain open-minded however 🙂
4 hours ago
Hi CeeBee2001
Apologies for this.
We are no longer able to switch off WIFI optimisation.
We can do some checks with you to see what is causing the interference. Our Community Star @KeithFrench provides really great advice on improving wireless performance.
