Turn off WiFi optimisation please
Noisynoodle
Message 18 of 18
Can I get the WiFi optimisation on my router turned off please? All our neighbours are bunched around the bottom few channels and I'd like to move us further up the band to get away from them, but every time I do, the auto optimisation moves the channel back down again.
17 REPLIES 17
Message 1 of 18
Glad this is now resolved for you.
Message 2 of 18
I moved it to CH 60 yesterday and so far it's stayed put, so it looks like you solved the problem, thank you.
Message 3 of 18
Hi Noisynoodle
As ferguson advises, DFS channel selection will affect some of the higher 5Ghz channels and this is nothing to do with wifi optimisation but something built into all UK routers using the 5Ghz band.
Message 4 of 18
@Noisynoodle That is a very high channel and may be subject to DFS correction. Try sticking to the 36 to 48 range.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don’t worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - TalkTalk Help & Support
Message 5 of 18
Hi Noisynoodle
Ok, can you monitor this again today because I've saved the settings again (WIFI optimisation switched off)
Noisynoodle
Message 6 of 18
Yes. I set the channel to one with no other signals  on it (Ch. 100) and after a couple of day it changes itself back to Ch.36, which is quite crowded locally.
Message 7 of 18
Hi Noisynoodle
Are you still experiencing this issue? (with wireless channels)
Message 8 of 18
OK Thank you
Message 9 of 18
Hi Noisynoodle
I've checked again and the WIFI optimisation is still showing as switched off.
Message 10 of 18
Yes, the correct landline number is in my profile.
Message 11 of 18
Hi Noisynoodle
Have you added the correct landline number to your Community Profile? (please do not post the number on this thread)
Skynet_TX
Message 12 of 18
Hi @Noisynoodle,
The staff here probably won't be around now until Monday, but they should be able to respond to this post early next week to help.
It may be that Wi-Fi Optimisation has switched back on again (if the router has been factory reset, or has applied a firmware upgrade), but if the 5GHz channel keeps changing, and the staff here confirm Wi-Fi optimisation is still switched off, then it is possible you are being affected by Dynamic Frequency Selection (DFS). All routers that broadcast a 5GHz signals have to comply with regulations that mean they check to see if the channel they are broadcasting on clashes with military / weather radar. If your router picks up a signal from military / weather radar on a 5GHz channel that could clash with the one your router is broadcasting on then your router must change channel. This is a legal requirement, and this functionality will be build into the router firmware, it can't be disabled.
Some more info on DFS can be found here : http://www.technical-direct.com/en/operating-wi-fi-network-5ghz-band-make-sure-deploy-dfs-first/
But the staff here should be able to check for you early next week, to see if Optimisation has become enabled again for some reason.
Message 13 of 18
It looks like the auto optimisation is on again as the router keeps resetting to channel 36. Can you take a look please?
Message 14 of 18
Hi Noisynoodle
That's great, I'm glad to hear that the speed has increased.
Noisynoodle
Message 15 of 18
Thanks for turning off optimisation. Download speed has increased from 40 to 61 mbps since changing the channel.
Message 16 of 18
Hi Noisynoodle
Apologies for this.
The WIFI optimisation has now been switched off. Let us know how the connection compares.
Gliwmaeden2
Message 17 of 18
Only staff can do this for you, @Noisynoodle.
They'll respond after the weekend.
