VPN not working on TalkTalk Hub version SG4K100130
Awaterhouse929292
Message 23 of 23
I have a router that is known for having problems connecting to the VPN of my business. Can I have a new router please so I can connect to my business?
22 REPLIES 22
Message 1 of 23
the router firmware is correctly set and our network colleague has checked the router.  Whilst the router will work with the majority of VPN clients and protocols, we cannot guarantee it will work with all clients.
You can try to change the DNS in the router to use google DNS, but this is not guaranteed to help.
Awaterhouse929292
Message 2 of 23
Sonicwall Global VPN client. Its sporadic when the VPN connects or not when on talktalk.
Message 3 of 23
What VPN Client / Program are you using ?
Awaterhouse929292
Message 4 of 23
Still not working guys
Message 5 of 23
Hi Awaterhouse929292
The firmware has now updated, please can you retest?
Message 6 of 23
I've asked a network colleague to apply a fix to your router for VPN to see if this helps.
Awaterhouse929292
Message 7 of 23
I've received the router and its been working better than before but the last couple of days its been impossible to work on my VPN. Are there any other fixes?
Message 8 of 23
it's on the way.
Message 9 of 23
yes please
Message 10 of 23
Hi.
If the VPN is actually connecting then the firmware should be correct, if the connection is intermittent then this could be the router itself. Would you like me to send a replacement ?
Message 11 of 23
Have done that and still the same intermittent connectivity.
Message 12 of 23
Your router has updated to the correct firmware version which should work ok with VPN.
Can you try factory resetting your router using the pin hole reset for ten seconds?
Message 13 of 23
Its still a problem
Message 14 of 23
Just checking back in to see if the VPN connection is now working ok?
Message 15 of 23
Should be done now, please test the VPN to make sure all is working now.
I'll also drop you a PM.
Message 16 of 23
I'll push the update now, only take a few minutes.
Message 17 of 23
Sure I do have a meeting at 3pm though
Message 18 of 23
Thank you. Will it be ok if I make a change to your router firmware this morning?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Awaterhouse929292
Message 19 of 23
hi ive added my number to my profile now
Message 20 of 23
If you log into My Account then your TalkTalk landline number should show there.
If you can't see the number in My Account then please add your account number to the Private Notes section of your Community Profile.
