iPhones keep losing WiFi connection
winter3
Message 25 of 25
Hi everyone,
In the past few months I've been experiencing problems with the TalkTalk Wi-Fi Hub router, specifically with mine and my partner's iPhones.
Every few minutes, probably dozen or so, the WiFi connection will drop (phone is still connected to the WiFi, but there's no internet) and I need to either disconnect and reconnect manually or leave it as it until it fixes itself 10-15 minutes later. As you can imagine, this is rather frustrating, especially considering that none of my other devices (laptop, PC, TV) that are connected to the router, whether via cable or wifi, experience the same issue.
My router's version is SG4K100174, all devices are connected to the 5 GHz band, the router is in the same room as me (and the devices), not using any extenders or anything else.
Additionally, might be related or not, the router's admin panel seems to break when trying to enable/disable the different wifi bands; a few weeks ago, I disabled the 2 GHz band but when I tried to re-enable it later, it would not work, no matter what I tried or what browser and device I used, so I had to factory reset the entire router in order to be able to get it back.
24 REPLIES 24
winter3
Message 21 of 25
hi @Debbie-TalkTalk
router has been restarted as requested and I'll take note of any disconnects over the weekend.
As my partner is away this weekend, I can't provide that information, however my personal phone and wifi connection details are below:
Phone: iPhone 13 Mini
OS: iOS 17.5.1
Wifi Connection Details (Under Settings -> Wi-Fi):
Auto-Join: True
Low Data Mode: False
Private Wi-Fi Address: True
Limit IP Address Tracking: True
IPV4 Address: Automatic
DNS: Automatic
HTTP Proxy: Off
Message 22 of 25
Hi @winter3
Thank you for updating your Community Profile.
Could you reboot the router for me please?
Which iPhone do you have? (model and IOS version)
Would it be possible to monitor the connection over the weekend after the router reboot and make a note of the dates and times this happens? I can then pass this to our Devices Team to take a look.
winter3
Message 23 of 25
Done, sorry about that
Message 24 of 25
Good afternoon,
  • Name
  • Telephone number
  • Alternative contact number
