iPhones keep losing WiFi connection
winter3
Message 25 of 25
Hi everyone,
In the past few months I've been experiencing problems with the TalkTalk Wi-Fi Hub router, specifically with mine and my partner's iPhones.
Every few minutes, probably dozen or so, the WiFi connection will drop (phone is still connected to the WiFi, but there's no internet) and I need to either disconnect and reconnect manually or leave it as it until it fixes itself 10-15 minutes later. As you can imagine, this is rather frustrating, especially considering that none of my other devices (laptop, PC, TV) that are connected to the router, whether via cable or wifi, experience the same issue.
My router's version is SG4K100174, all devices are connected to the 5 GHz band, the router is in the same room as me (and the devices), not using any extenders or anything else.
Additionally, might be related or not, the router's admin panel seems to break when trying to enable/disable the different wifi bands; a few weeks ago, I disabled the 2 GHz band but when I tried to re-enable it later, it would not work, no matter what I tried or what browser and device I used, so I had to factory reset the entire router in order to be able to get it back.
24 REPLIES 24
Message 1 of 25
OK, I'll feed this back to our teams.
winter3
Message 2 of 25
Hi @Karl-TalkTalk ,
Thanks for getting back to me! IP address does not work either and upon checking the router UI, the iPhone does not appear in the listed WiFi devices at all, even if the phone itself claims it is connected to the WiFi.
Message 3 of 25
Our devices Team - after speaking with sagemcom have asked if you can test the following.
When the connection fails, can you try accessing a website via IP address for example 142.251.36.46   (google.com)
This will bypass DNS.
Message 4 of 25
Nothing back from Sagemcom as yet, but the Team are still pressing them for an update.
winter3
Message 5 of 25
Hi @Anonymous @Debbie-TalkTalk ,
Sorry for mentioning you on this again, but I was wondering if there has been any updates? This is still happening consistently.
Message 6 of 25
I'm sorry for the delay with updates. Our Devices Team are still looking into this with Sagemcom.
Message 7 of 25
Hi @winter3
I've asked our Devices Team for an update and I will post back here as soon as they come back to me with additional information.
Message 8 of 25
Hi winter3
Our Devices Team have advised that they are still investigating this issue. As soon as they provide further updates then I will post back on this thread.
Message 9 of 25
Thanks @winter3 for the additional information.
I should hopefully have further updates from our Devices Team later today.
winter3
Message 10 of 25
Hi @Debbie-TalkTalk ,
Just wanted to update you on this; unfortunately, disabling the "Private Wi-Fi Address" and "Limit IP Address Tracking" options for the wifi connection had no effect whatsoever and the connection still dropped at:
Monday: 15:10, 15:50
Tuesday: 10:30, 15:50
Wednesday: 12:05, 14:20
Message 11 of 25
Hi @winter3
Thank you. I will continue to feed back any examples or information to our Devices Team whilst they are investigating.
winter3
Message 12 of 25
Will do, for next few days, I will disable the "Private Wi-Fi Address" and "Limit IP Address Tracking" for this connection on my iPhone and see if that has any knock-on effect.
Message 13 of 25
Hi @winter3
Thank you for confirming 🙂
I have passed over all your examples to our Devices Team and I will post back here as soon as I have further information.
If you could keep noting example dates and times of when this fault occurs that would be appreciated.
Thanks again.
winter3
Message 14 of 25
I did, yes, roughly around the time you requested me to do so.
Message 15 of 25
Hi @winter3
Did you reboot the router on Friday?
winter3
Message 16 of 25
Hey @Debbie-TalkTalk ,
Not great unfortunately. I've recorded the approximate time of when each drop occurred, "drop" being measured by the phone appearing to be connected, but no actual internet connection being established - web applications displaying "Connecting" and web browsers failing to reach any website.
Friday: 14:40, 16:28
Saturday: 8:40, 13:01, 13:10, 15:30, 17:15, 19:23, 19:45
Sunday: 11:45, 19:35, 22:00
Monday: at around 9:00, the router itself lost connection to the internet and all my devices went offline; 9:40.
This is what I see on my phone when I try to reach google.com and I know for a fact that the connection isn't there, even if the wifi icon is on:
iPhone no wifiiPhone no wifi
This is what I see on the router's UI when the phone is in such a state:
iphone router status dc'diphone router status dc'd
And it changes to this once I stop and restart the wifi and the connection is alive again:
iphone router status aliveiphone router status alive
Message 17 of 25
Message 18 of 25
Hi @winter3
Ok, thank you.
I am looking at another case of this happening at the moment but it's not the same model of iphone. We are looking at example dates and times provided to try and pin point the issue.
winter3
Message 19 of 25
@Debbie-TalkTalk
No, not yet. I want to see if it's a configuration error of a sort, I'm sure that will also be helpful in the long run for your team too, in case other customers report the same issue. I can also play around with my iPhone's connection settings and see if that might have been causing it, let's give it some time to test things out and narrow down the problem. If nothing works, we can look into replacing the router.
Thanks!
Message 20 of 25
Hi @winter3
Would you like me to send a replacement router too so we can rule this out?
