So yesterday i had an engineer out to fix my slow broadband connection. He completed his work and shown me that i was getting around 80 mbps download and around 20 mbps upload. I then went onto my router page which shown this as correct.
I ran a speed test to see what i was actually getting and turns out im not even getting near the 80 mbps.
Before my issue i was getting around 72mbps but now im getting around 24mbps.
How do your devices connect to the router, via wifi or wired (Ethernet) connections? If a mixture are the Ethernet ones faster than the WiFi?
Hi KeplerX
Apologies for this.
I've checked the connection stats and your line is showing in sync at 80mb.
Please can you power down your router for a full 30 minutes and then run a speed test following this?
