Since installing the WiFi hub, and in particular over the last few days, my connection is much less stable. My HG635 would stay up for weeks on end. The hub seems to be falling over very frequently.
Annoyingly it does not log connections, so I can't tell how often, but I know it must have been 3 or 4 times yesterday.
Do I just swap back to the HG635?
Hi @CraigMcK27 , welcome to the community your post has been flagged for assistance. It might be your hub is defective, but if I had a working HG 635 I would use it!
Hi Craig,
I'm sorry to hear this. I've run a test on the line which has detected a potential fault. Just to confirm, are you experiencing any issues with the voice service such as noise on the line or no dial tone?
Thanks for getting back to me.
We don't use the landline. But I've just checked and we have a dial tone now and no noticeable noise
Hi Craig,
Could you swap back to the HG635 and check if you are still experiencing the problem. If you are then we'll log it over to Openreach for further investigation
OK thanks, please let us know how you get on
