I added speed boost to fast fibre 3 weeks ago with a promise of a minimum download speed of 56mbps. When it first connected the WiFi hub dashboard showed 66.1mbps download and 20mbps upload speeds. Within days the speed dropped to low 40's and is currently about 47mbps, there have been occasions when monitoring it during past week when speed drops to single figures and low 20's. The connection has also been unstable, dropping out at least 6 times in the last week. Upload speeds seem to be generally reasonable. Can TalkTalk please adjust settings to give me the speeds promised or higher and a stable connection.
Sync has increased to 55mb.
Can you check the home phone and tell me if there is any noise or interference on the line.
I am detecting a bridge tap when testing.
OK, as the tests are still picking this up I've asked networks if we can arrange a non appointed Openreach engineer or if they will request an appointment.
I'll let you know as soon as I get an update from them.
Openreach are requesting an appointment. I'll drop you a PM with the info required etc.
Hi Mac55,
I've replied to your PM
Initial problem with speed issues was resolved following visit by TalkTalk engineer and then a Openreach Engineer, which resulted in Openreach confirming download speed was now 80mbps and upload of 20mbps on 21st August. WIFI router dashboard confirmed the same with actual speed test giving 77mbps download, which was brilliant.
Until 4 days ago, when router reset itself and download on dashboard showed 78.5mbps download and 20mbps upload. Speed test initially dropped to mid 60's mbps but since then has dropped significantly initially to 15mbps download and now about 36mbps.
I raised this issue in a personal post and was asked to raise problem in this forum so it can be addressed.
All speed test are done over wired connection.
Please also note the Openreach Engineer confirmed when he visited that the line was more than capable of staying at 80mbps plus download speed.
Could you please address this and get the speeds back to where they should be with out delay.
Hi Mac55,
Thanks for posting on your thread 🙂
I'm sorry to hear you're experiencing problems again with your service. Line test isn't picking up any issues and your router is in sync at 78.5Mbps
Can you switch your router off for at least 30 minutes then switch back on and run a couple of speed tests to see if there's any improvement
Switched of router for 30 plus mins then restarted. WIFI router dashboard confirmed line speed 78.7mbps download. Ran series of speed tests, initial one at 74.97mbps then 64mbps, 19.1mbps (!)Hour later 62/ 75.6 and 46.65mbps.
This morning did a further series of speed tests as follows :
60 then13.5 (!) 70.8, 36, 63 then 77.5 (!) then 56 and 39 - all Mbps.
As you can see jumping to extremes and disappointing given it had be running well until 5 days ago.
Hi Mac55,
Thanks for the update. When you ran the speed tests did you have many devices connected to the line at the same time? Does the speed seem to drop at a certain time of the day or is this random?
Two other devices , ipad and mobile connected but this is no different to when things were previously running ok.
Random times, not necessarily any particular time.
Could it be the router?
Hi Mac55,
Thanks for letting me know. Do you have an alternative router that you could test with to see?
Would you like to try a replacement hub or a different model to see how the speeds compare.
Replacement hub would seem to be best option as the one I have was fine until 5 days ago and I believe it is still TalkTalks most recent model?
Ok, replacement hub on the way.
No Problem 🙂
Fingers crossed at the ready.
