on 27-09-2020 08:53 AM
Since joining TT all of my 2.4Ghz devices have been periodically dropping off wifi and then reconnecting a few minutes later. This is apparent and logged as I have a Nest doorbell they only works on 2.4Ghz and is only 1m away from the router. Each time the doorbell disconnects I get sent an email notification, of which I have lots now. I have tried changing the wifi channel, first seeing which were free using a wifi analyser. But this hasnt helped. I suspect I have a faulty router as this never happened with my old Sky router. Is anyone else experiencing the same problems?
on 27-09-2020 09:10 AM
Slow speed, intermittent dropouts, breaks in the signal, or no signal on some or all devices, might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-fi.
To enable me to help you, please can you specify the make/model of TalkTalk router that you are using?
