Cannot connect to work cisco anyconnect VPN since 17/09/2024
AndyBeast25
Message 17 of 17
Hi.
I've been unable to connect my work VPN to work at home since 17th Sept 2024.
I'm at work and they have said something must have changed with my home broadband. I've tethered my mobile phone and can connect OK with that. My work IT have confirmed nothing has changed with the work equipment and no other users are reporting issues.
When I try to connect the VPN, it searches but cannot find the remote access server. Then finally reports this error "Could not connect to the server. Please verify internet connectivity and server address.".
Internet is working as off the VPN I can browse as normal. Only the VPN doesn't work.
Has something changed with the Talk Talk router or broadband please? I need to be able to work from home.
Any help appreciated.
Andy
16 REPLIES 16
Message 1 of 17
Thank you. I can see that we've posted on your topic.
Message 2 of 17
Done, thanks
Message 3 of 17
Hi @bpankhurst
Please can you create a new topic here Broadband - TalkTalk Help & Support
We can then take a look at this for you.
bpankhurst
Message 4 of 17
Hi, I am having exactly the same issue, please can someone assist?
Message 5 of 17
Hi @Juniorhubcap
I will take a look at your thread now.
Message 6 of 17
Staff will reply during the day, @Juniorhubcap, on your own thread.
Juniorhubcap
Message 7 of 17
I  having the same issue as this since earlier this week can I get the same fix?
Message 8 of 17
Hi Andy,
There was a firmware update and we have seen a few customers having VPN issues, but only with the one client - Cisco Any Connect.
We have rolled back the firmware while our teams look at the settings, and have this corrected before we continue to update to the next firmware.
Message 9 of 17
Just out of interest Karl.
Are you at liberty to say how the problem came about?
Andy
Message 10 of 17
You're Welcome 🙂
Message 11 of 17
Hi Karl.
I'm happy to report that I'm back home and connected to work now via VPN.
So looks to be fixed.
Thanks again for your prompt fix. Really appreciate it 👏
Andy
Message 12 of 17
No Problem 🙂
This small correction has worked for all so far, so no reason it should not work for you.
Message 13 of 17
Thank you Karl.
I'm not at home as I had to travel to work to be able to work. I'm going to return home in an hour or so.
I'll test then and let you know.
Thank you for your help
Andy
Message 14 of 17
I've made a change to your router, give this a test now and let me know.
AndyBeast25
Message 15 of 17
Hi Karl.
I've added in my account number to my profile. Thanks for your help
Andy
Andy
Message 16 of 17
Can you add your home phone number or account number to your 'Community Profile' so I can locate your details on our system.
