WiFi Channel Resetting
Squidge87
Message 8 of 8
Can you please switch off the WiFi Optimisation as it keeps resetting 5Ghz to channel 36 which is unstable/overcrowded, I set it to 108.
I have had this done before but recently switched over routers so need this switching off again.
7 REPLIES 7
Message 1 of 8
Hi connor27,
If you need assistance can you please start your own thread/topic and we'll be happy to help
connor27
Message 2 of 8
I’m getting no connections to any device
Message 3 of 8
Thanks for your help @KeithFrench
Message 4 of 8
No problem, I ended up swapping back in the older one.
Message 5 of 8
Hi @Squidge87
There may be another option, but I need to check with another customer who has had this applied to their Sagemcom. I will PM this customer now & when they come back to me, I will know whether this has worked or not.
Message 6 of 8
Ah fair enough, il wait until Monday if they can’t do it anymore il swap back in the previous router which had it done and stays on the channel I select!
Gliwmaeden2
Message 7 of 8
It can't be done any more, @Squidge87.
@KeithFrench may be able to advise you further. Staff won't be back on here before Monday.
