Capped Upload speed
internetlover
Message 7 of 7
Since moving over to GFast my upload speed seems to be capped at 29Mbps. Im sure that i used to get around 40+ when on regular fibre?
Is there a cap on the upload speed? I realise the download is capped at 'Fast 150'.
6 REPLIES 6
Chris-TalkTalk
Message 1 of 7
Hi internetlover,
Just to confirm, as previously advised, the max upstream speed on g.fast 150 is 30Mbps so the speed you are getting is pretty good 🙂
Message 2 of 7
As others have said 30Mbps is the maximum upload for G.fast 150, so you seem to be doing just fine.
Message 3 of 7
Hi Michelle,
My upload speed seems to be capped at 29mbps. Can you confirm if there is a speed cap in place?
Message 4 of 7
Hi internetlover,
How are you getting on? Are you experiencing any issues with the performance of the connection? What speeds are you currently seeing if you run a wired speed test?
Skynet_TX
Message 5 of 7
Hi @internetlover ,
Max speeds possible are :
Faster Fibre 40mbps down / 10mbps up
SuperFast Fibre (i.e. Faster Fibre with Speed Boost) 80mbps down / 20mbps up
Fibre 150 150mbps down / (and based on a bit of googling, I think) 30mbps up
FritzCT
Wise Owl
Message 6 of 7
I think the fastest FTTC upload is 20 so you wouldn't have got 40.
