Disable UpNP
jacktickoo
Message 2 of 2
I have some hardware that requires port forwarding to be set up to work correctly but because I am unable to disable UpNP it is creating a conflict and huge issues with my device. I have tried looking everywhere in the router settings to disable UpNP, and can't find the option anywhere, and I notice that some people on these forums have had UpNP disabled remotely from tech support. Can someone do this for me please? It's reaching a point where i'm going to need to switch provider if I can't turn UpNP off.
Thanks very much for any advice or support.
1 REPLY 1
Message 1 of 2
I've answered in your original thread, can you please keep replies to that thread and i'll close this as a duplicate issue 🙂
