Eero blocks my PC searches
Olivia11
Message 5 of 5
Hi we received our eero modem a few days ago. All good BUT when using my PC, it seems to block transitions from the search menu. For example, if I search the term 'dementia' and then try to follow a link indicating information sheets, the search flags up that the site cannot be reached.
Any suggestions??
Thanks in hope!
4 REPLIES 4
Message 1 of 5
Thank you Keith - much simpler than the instructions in the other thread of a similar nature.
Interestingly, the problem seemed to have resolved itself last night following the email indicating we were now fully connected to the fibre.  So, it may have been a teething issue.
Keep up the support!
Message 2 of 5
Hi @Olivia11
To enable or disable eero Secure, from the eero app go to:-
  1. Tap Discover
  2. Tap eero Secure
  3. Tap Advanced Security to toggle the feature on or off.
Message 3 of 5
Thanks @KeithFrench
Message 4 of 5
I did see someone else with this, I think that you have to disable Eero Secure's Content filtering section within the app. I think I made a note of this, but it is on my other PC. I will try & check it tomorrow.
