Ethernet cable speed test not wifi
Marvel
Whizz Kid
Message 19 of 19
I can not find the talktalk speed test for wired connections as it only works for wifi. There used to be a wired connection but now I can not find it
18 REPLIES 18
Message 1 of 19
Thanks for the update 🙂
Marvel
Whizz Kid
Message 2 of 19
Thanks everyone for your help. Its now sorted, it was because I was signed in or at least partly signed in although I was not signed in to my account my phone number was still displayed on the test webpage so I went into the page cookie settings and clicked reject all and refreshed the page - my phone number was no longer displayed and the test ran ok via wired.
Gliwmaeden2
Message 3 of 19
@Anonymous, might it be worth @Marvel trying to run a test directly from the community linked page?
I am able to run the test WITHOUT being signed into My Account,  @Marvel.
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Message 4 of 19
The speed test tool should test both wired and wireless speeds. I'm wondering if it is maybe a typo on the help page so I've asked the team to confirm.
Marvel
Whizz Kid
Message 5 of 19
My wired devices are fine and run faster than wifi like they should. When I press the test button i see this
testtest
It then changes to this
speedspeed
I seem to be on a page that only tests over wifi. If you read the page of the link I posted it only talks about wifi.
Message 6 of 19
I've just ran a wired speed test and it worked for me. When you click the test my speed button does the test then not run at all? Do your wired devices feel slower than your wireless devices or did you just want to compare the speeds?
Marvel
Whizz Kid
Message 7 of 19
Actually I see the page address says "new" at the start. I wonder if AllyM is using something different. Perhaps the New has gone totally wifi
Marvel
Whizz Kid
Message 8 of 19
I can try a different port but not sure how that will change the talktalk website from saying
Our speed test measures how quickly data is being sent and received over your Wi-Fi connection.
Here https://new.talktalk.co.uk/broadband/speed-test.
Have a read through its all about wifi. Am I on the wrong talktalk test page.
I have 4 devices connected via Ethernet but only 1 in use at the minute.
Message 9 of 19
Have you tried connecting to a different ethernet port on the router? How many wired devices do you have?
Marvel
Whizz Kid
Message 10 of 19
Here is what the talktalk speed test website says
testtest
It doesn't actually mention wired anywhere - only everything that can affect your wifi signal .
Yes it works ok on wifi.
Odd that AllyM has no issues using a wired connection but I have no option to run a wired test.
Message 11 of 19
So just to confirm, if you run the same speed test when connected wireless it works fine?
AllyM
Message 12 of 19
I've no idea why you're getting that, sorry. Like I said, I am testing using PC connected by ethernet and the speed test runs fine.
Marvel
Whizz Kid
Message 13 of 19
Thanks, Is that with a wired connection because I get this (
No devices connected
There are no devices connected to your Wi-Fi network.
To see the speed to your devices please make sure they are turned on and connected to your Wi-Fi.)
speed testspeed test
AllyM
Message 14 of 19
I just log into MyAccount and click on the "run a speed test" box on the first page.
Link goes to here: TalkTalk - Service Status
Message 15 of 19
Thanks Karl
Marvel
Whizz Kid
Message 16 of 19
That's right neither do I but I am sure it was just one test option that did both wired and wifi but now its only for wifi.
Where is the talktalk one you are using for a wired connection please.
AllyM
Message 17 of 19
I don't remember there ever being a separate speed test for wired connections. Why would there be? The normal TalkTalk speed test still works fine for me via a wired connection.
Message 18 of 19
I often use Sam Knows Speedtest  and find this as accurate as most others.
