Faster Fibre - router: all green lights, no internet
Borka
Message 16 of 16
I´ve got a problem with my connection (Faster Fibre+Speed Boost).
Broadband+Internet on the router (HG633) is green, but nothing works, only ping/tracert, both on wired and wireless. Factory reset did not help. Tried another 2 routers, but everything still remains the very same. Tried both of my computers from neighbour´s connection (he is with TalkTalk as well) and everything is working fine. Tried my router at his and everything was good. Replaced the DSL filter, all cables, no change.
Router - Connection Status says ADSL2+, instead of VDSL/2.
I would be most grateful if you could run a test line or anything to give me some information.
Also wanted to try the test socket only to find this:)
tried plugging it straight into it anyway, but the very same result as before.
Thanks a lot for any info/help.
Marian
15 REPLIES 15
Message 1 of 16
That's great news, glad it's all working for you now.
Any issues, just give us a shout.
Borka
Message 2 of 16
Engineer has finished, everything's working like a charm. Thank you all for all the help!
Message 3 of 16
Thanks for letting us know. Please keep us informed after the engineer has completed the tasks with you.
Borka
Message 4 of 16
Just got a call from Openreach engineer, he will be working on it today, will let you know once he will be finished.
Borka
Message 5 of 16
It's been over 24hrs., but the situation is still the same: different line/number, thus still no connection.
Message 6 of 16
Thanks for testing and confirming. The line test is detecting a potential external issue so I've passed this over to Openreach now to complete an external line investigation. If you don't hear anymore in the next 24hrs then please let us know and we can re-check for an update on the fault for you.
Skynet_TX
Message 7 of 16
It is probably just that they have their ADSL service from a different ISP, and the connection settings of your TalkTalk router will not work properly with that other ISPs service.
It is well worth having a landline phone if only to be able to do tests like this, as diagnosing a problem like this is very difficult for TalkTalk, as if they run a line test it may well come back and say everything is fine, and everything may well be fine, but it is actually connected to someone else's house, and there is no way their line tests can know that !
Borka
Message 8 of 16
Thanks a lot for the phone idea, would not even think about that. I would be glad to have at least that ADSL service of theirs, than no service at all:)
Message 9 of 16
Ok, so if 17070 is reading back the wrong number then Openreach have messed up, so you probably have one of your neighbours lines (who only has ADSL), and one of your neighbours will have your phone number and VDSL service !.
The staff here will be able to help tomorrow, they will need to call Openreach out again to get things fixed.
Borka
Message 10 of 16
Landline phone connected, dial tone and making calls all good, but as @Skynet_TX  said, I am on a completely different line/phone number.
Message 11 of 16
Ok thanks for the update. If there is no dial tone or noise on the line then we can raise this as a voice fault. If the voice service is ok then we will raise this as a broadband issue for further investigation.
Borka
Message 12 of 16
I"m getting one today as both of you suggested and will let you know the results this evening.
Message 13 of 16
Hi Borka,
I'm sorry to hear this. I've run a test on the line which has detected a possible voice fault. Did you have a chance to test with a phone to see if there is a dial tone please?
Borka
Message 14 of 16
Hi and thanks for the reply. Unfortunately I don't have a landline phone, might try to get one tomorrow, we'll see what the staff will say.
Skynet_TX
Message 15 of 16
Hi @Borka,
If you have a landline phone can you try dialling 17070, does this read back your correct phone number. If your router is suddenly reporting that it is connected to ADSL rather than VDSL then I'm wondering if Openreach have messed up and connected a different line to you whilst doing some work locally.
Staff will be able to reply tomorrow to help further.
