Fibre speed drops to near zero overnight
LittleReggie1
Message 16 of 16
Apologies for this long-winded post, but...
Almost every morning first thing (e.g. 6.30am) when I start to use the internet, I find that the speed has dropped to sub 1 Mbps. If I check the router (DG8041W) it may have re-synced in the early hours (but not always), but regardless always seems to be synced around its maximum attainable 29 Mbps. If I reboot the router or even just restart the DSL, the download speed immediately returns to around 27-28 Mbps and is fine for the rest of the day. This cycle repeats almost daily now, but has actually been going on for 6 months or more in some form.
If I try my previous TalkTalk router (can't check the model just now) the behaviour is different. It syncs at a lower speed, the sync speed tends to drop daily, and eventually seems to settle around 17-18 Mbps, giving me 15 Mbps download speed if I'm lucky (but it's more stable). I haven't left this router connected long term to see if anything changes after this.
While this has been going on, I've had an apparent line fault repaired and later run an automated TalkTalk test which advised me to test my own setup. I have an Openreach master socket with the pre-filtered FTTC faceplate. I tried the test socket to no effect when this problem first occurred months ago, but not since the line fault was repaired. I don't have a landline phone connected at all now.
I'd be grateful for any suggestions.
15 REPLIES 15
Message 1 of 16
No Problem 🙂
LittleReggie1
Message 2 of 16
I didn't consciously wait 30 minutes, but it would almost certainly have been longer than this when I installed the new router. When re-installing the DG8041W router I was much quicker, but this has already synced at a far higher rate and the advanced settings imply a far higher maximum sync speed for my line (30+Mbps as opposed to 21Mbps with the Sagemcom). I think this can only be down to the design of the router.
It's good to know that I can return either router.
Message 3 of 16
you can return the new router.  When swapping over the router, did you power down for 30 minutes to start a new session.
LittleReggie1
Message 4 of 16
A quick update. First impressions of the new router are that it works ok, but sync rate and actual download speed are significantly lower. Now stability is important, but we are talking 20Mbps as opposed to 28Mbps with the DG8041W. That's quite a difference on a relatively slow connection.
I have been given a date by which to return the old router or pay a forfeit. I have re-installed the DG8041W for the time being, so if this proves to be the better option can I return the new router instead?
Message 5 of 16
Hi LittleReggie1
Ok no problem, please let us know how you get on.
Message 6 of 16
A power cut spoiled things yesterday.
I will install the new router today and, yes, it would be helpful if I could hang on to the old router for a little while.
Message 7 of 16
Hi LittleReggie1
Would you like to monitor the connection for a little while longer before returning the router? (just incase you do experience any issues)
Message 8 of 16
Hi Debbie,
I have a dilemma now. I have not swapped the routers yet, but this problem seems to have mysteriously fixed itself, as I haven't had a drop in speed, DSL re-sync or online re-connection for about 5 days now?
I'm reluctant to disturb anything at the moment as the internet is used for homeworking, so is there an option to just buy the new router?
Message 9 of 16
Hi LittleReggie1
Thanks for your reply. How are you getting on?
Please can you keep the new router and return the old router using the pre paid returns bag.
Message 10 of 16
New router arrived today (Saturday). A job for tomorrow hopefully. What's the deal with the new router - do I get to keep it and return the old one?
Ironically, I have not had the usual problem the last two mornings.
Message 11 of 16
Hi LittleReggie1
Sorry for the delay.
Have you received the router since your last post?
Message 12 of 16
In the meantime, and in case the new router doesn't solve the problem:
Same scenario this morning. At 5.20am everything was running at a crawl. I did a few speed tests and it was showing 2-3 Mbps. I checked the router settings and, interestingly, on the dashboard it was reporting an "online" time of 1 hour 40 minutes, but further into the settings it was reporting a DSL "sync" time of 20+ hours (when I last manually resynced). Another manual DSL resync got everything back to normal speed again.
So does this imply that it is the PPPoE session reconnecting when the speed drops? Is there a PPPoE session with this type of connection? If not, what is the difference between synced and online, and why would the online connection drop in the early hours?
Message 13 of 16
Hi LittleReggie1
No problem 🙂
Let us know how the connection/speed compares with this router.
Message 14 of 16
Hi Debbie,
Yes, that would be great, thanks!
Regards.
Message 15 of 16
Hi LittleReggie1
The line test has not detected any faults and the line is in sync at 29.4mb.
Would you like me to send a Sagemcom WIFI hub for testing to see how the connection compares?
