on 09-09-2020 07:18 PM
Hi, I upgraded to the fibre speed boost and it went live early August.
Everything was fine and I was getting 60+ MBps download and 20 upload.
A few days back, I noticed upload went down to 17, The next day, 15. The day after 12 and finally today it synced at 10.
Download speed is unchanged at around 63 MBps
Please can you explain why the upload speed has halved (and is back to what it was before I upgraded to the fibre speed boost).
Thanks,
Alex
on 23-03-2021 11:31 AM
Hi Alex,
Apologies for the delay, I've disabled wifi optimisation as requested
on 22-02-2021 11:17 PM
Yes please
on 22-02-2021 07:21 AM
Hi oloolo,
I'm sorry for the delay. We can switch the wifi optimisation off, would you like to try this?
on 13-02-2021 01:40 PM
Hi, The new modem has been working well the last couple of months, connection is stable and no kernel panics.
The only thing I have noticed is that the wifi channel is automatically changed to a busy channel after a while, even if I set the channel manually (i.e. not set to "auto").
The channel it changes it to is very busy and the channel I pick is empty.
Is there a way to stop the modem changing the wifi channel once I set it?
on 31-12-2020 12:26 PM
Hi Alex
Thanks for letting us know. I've checked and I can see that the router firmware has now updated to the latest version.
Please let us know how the connection compares.
on 30-12-2020 01:49 PM
The new modem has arrived. I can see it's an old firmware version but I guess that will update over time. The modem synced same speed as my old one i.e. 60.0 down and 19.0 up.
Hopefully the wifi will be more stable (with no kernel panics), I'll let you know in a few days,
thanks
Alex
on 29-12-2020 10:08 AM
Hi oloolo
Debbie 🙂
on 29-12-2020 09:41 AM
Yes please that would be worth a try,
on 29-12-2020 06:24 AM
Hi oloolo
I'm really sorry for the delay.
Would you like me to send the Sagemcom WIFI Hub for testing to see how the connection compares?
on 20-12-2020 12:55 PM
As you can see from the December log, the hub is still rebooting often, sometimes several times per day. I've had no reply to my last few posts which is disappointing, the forum was a good way to progress issues but why is this issue is being ignored?
It's causing problems particularly when working from home! It looks like there is something wrong with the hub or the software that it's running. Please can you look in to this.
extract from December log below:
Manufacturer:Huawei Technologies Co., Ltd; |
ProductClass:DG8041W; |
SerialNumber:xxx; |
IP:192.168.0.2; |
HWVer:I.1.01; |
SWVer:v1.05t; |
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2020-12-03 00:11:04 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-03 00:11:04+00:00], uptime is [34s].
2020-12-03 00:12:45 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-03 00:12:45+00:00], uptime is [35s].
2020-12-04 17:11:24 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-04 17:11:24+00:00], uptime is [35s].
2020-12-04 17:13:04 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-04 17:13:04+00:00], uptime is [34s].
2020-12-05 10:01:09 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-05 10:01:09+00:00], uptime is [35s].
2020-12-05 10:02:43 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-05 10:02:43+00:00], uptime is [36s].
2020-12-05 13:26:12 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-05 13:26:12+00:00], uptime is [38s].
2020-12-05 17:51:20 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-05 17:51:20+00:00], uptime is [34s].
2020-12-05 18:46:19 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-05 18:46:19+00:00], uptime is [35s].
2020-12-06 07:56:15 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-06 07:56:15+00:00], uptime is [38s].
2020-12-07 15:16:26 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-07 15:16:26+00:00], uptime is [34s].
2020-12-11 12:36:10 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-11 12:36:10+00:00], uptime is [35s].
2020-12-13 19:46:45 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-13 19:46:45+00:00], uptime is [39s].
2020-12-13 20:46:13 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-13 20:46:13+00:00], uptime is [36s].
2020-12-13 22:11:02 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-13 22:11:02+00:00], uptime is [32s].
2020-12-16 17:35:57 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-16 17:35:57+00:00], uptime is [35s].
2020-12-17 07:21:10 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 07:21:10+00:00], uptime is [35s].
2020-12-17 07:22:51 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 07:22:51+00:00], uptime is [38s].
2020-12-17 08:56:05 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 08:56:05+00:00], uptime is [37s].
2020-12-17 08:57:44 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 08:57:44+00:00], uptime is [34s].
2020-12-17 10:36:17 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 10:36:17+00:00], uptime is [39s].
2020-12-17 12:16:08 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 12:16:08+00:00], uptime is [34s].
2020-12-17 12:35:41 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 12:35:41+00:00], uptime is [32s].
2020-12-17 13:16:07 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-17 13:16:07+00:00], uptime is [35s].
2020-12-18 18:31:05 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-18 18:31:05+00:00], uptime is [34s].
2020-12-19 03:01:12 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-19 03:01:12+00:00], uptime is [32s].
2020-12-19 04:11:21 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-19 04:11:21+00:00], uptime is [39s].
2020-12-19 05:51:23 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-19 05:51:23+00:00], uptime is [39s].
2020-12-19 05:52:51 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-12-19 05:52:51+00:00], uptime is [32s].
on 01-12-2020 12:38 PM
No opinions on this? The hub is rebooting 1-2 times per day but the WiFi reaches all parts of the house.
However the old super router has a stable Internet connection but poor WiFi.
Will a firmware update fix the hub or is it faulty?
on 25-11-2020 01:05 PM
Hi OCEs, do you agree there appears to be a problem with the hub?
on 22-11-2020 02:18 PM
I have been using the HG635 ever since the problems started with the WiFi hub i.e. upload speed decreasing.
It's been fine on the HG635 ever since, but the WiFi is not as good. So I am using the HG635 as a modem and connected it to the WiFi Hub to use it's WiFi capabiliy.
HG635 connection is stable:
The WiFi is more powerful on the hub when it is working, but as observed by other community members the WiFi Hub's wireless is unreliable with frequent restarts of the wireless due to kernel panic.
My WiFi hub is suffering from the same problem, as can been seen by the log below of the kernel panics since 1st November. The problem is getting worse.
Since I have had problems with the upload speed on the wifi hub, as well as kernel panics, is there a firmware update that would fix this or is the modem faulty?
Alex
Kernel panics in November:
01/01/1981 00:00 [Error][Alarm-Log] Ala rmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
01/11/2020 13:56 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-01 13:56:38+00:00], uptime is [36s].
01/11/2020 13:58 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-01 13:58:02+00:00], uptime is [34s].
02/11/2020 11:35 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-02 11:35:46+00:00], uptime is [36s].
02/11/2020 11:37 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-02 11:37:20+00:00], uptime is [35s].
02/11/2020 11:56 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-02 11:56:12+00:00], uptime is [38s].
03/11/2020 11:16 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-03 11:16:06+00:00], uptime is [34s].
06/11/2020 09:06 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-06 09:06:35+00:00], uptime is [38s].
06/11/2020 09:08 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-06 09:08:07+00:00], uptime is [38s].
07/11/2020 13:31 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-07 13:31:10+00:00], uptime is [34s].
08/11/2020 22:56 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-08 22:56:35+00:00], uptime is [37s].
09/11/2020 05:41 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-09 05:41:08+00:00], uptime is [35s].
09/11/2020 22:47 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-09 22:47:17+00:00], uptime is [35s].
10/11/2020 03:11 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-10 03:11:07+00:00], uptime is [34s].
10/11/2020 03:12 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-10 03:12:34+00:00], uptime is [35s].
10/11/2020 12:26 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-10 12:26:10+00:00], uptime is [38s].
12/11/2020 02:56 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-12 02:56:07+00:00], uptime is [37s].
12/11/2020 10:21 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-12 10:21:15+00:00], uptime is [38s].
13/11/2020 23:11 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-13 23:11:22+00:00], uptime is [39s].
15/11/2020 13:56 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-15 13:56:15+00:00], uptime is [38s].
15/11/2020 20:56 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-15 20:56:25+00:00], uptime is [35s].
15/11/2020 20:57 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-15 20:57:55+00:00], uptime is [34s].
20/11/2020 02:41 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-20 02:41:18+00:00], uptime is [33s].
21/11/2020 05:26 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-21 05:26:12+00:00], uptime is [35s].
21/11/2020 05:27 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-21 05:27:47+00:00], uptime is [38s].
21/11/2020 13:51 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-21 13:51:15+00:00], uptime is [39s].
21/11/2020 13:52 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-21 13:52:40+00:00], uptime is [34s].
21/11/2020 14:51 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2020-11-21 14:51:15+00:00], uptime is [33s].
on 05-10-2020 09:06 AM
OK, thanks for the update
05-10-2020 08:46 AM - edited 05-10-2020 08:48 AM
I left the hg635 connected until Friday, there were no connection drops and speed was fast I. E. 71 down and 20 up.
I connected the WiFi hub on Friday and the download dropped to 62 and upload remained at 20.
However on Sunday morning dlm reduced the upload to 19 with download staying at 62.
I have reconnected the hg635 and the download is now 71 but the upload remained at 19.
I'll leave it a couple of days to see if the upload goes back to 20.
on 29-09-2020 11:11 AM
Hi oloolo,
I'd probably give a couple of days with the HG635 and if the connection remains stable you could then try going back to the wifi hub
on 29-09-2020 09:54 AM
Yes the upload speed is back to normal and uploading files to one drive is fine.
I do have an hg635 connected rather than the WiFi hub. Do you think there is a problem with it or shall I try reconnecting it?
on 29-09-2020 07:56 AM
Hi oloolo,
Your upstream sync speed is now back to 20Mbps, DLM changed your profile in the early hours of this morning, have you noticed a speed improvement?
on 27-09-2020 05:55 PM
Let's hold off the engineer for now.
I received a text from talktalk over the weekend saying the incident that caused the fault on my line has been fixed.
I have my old HG635 modem currently connected to see if DLM improves the upload speed on that (and it will rule out any problems with the Wifi hub). Or am I better off reconnecting the Wifi hub? I have not seen any changes in the upload profile, it's still 799.
Can you see any connection issues at the exchange end or will DLM now ramp up the upload speed? Since the download speed is syncing fine is it likely there is a cabling issue at home that only affects the upload? It doesn't seem very likely. Is there a way of resetting the DLM to speed up the process since the fault is now reported as fixed?
Statistics from HG635 which I connected on Sunday PM after powering off 35 mins:
Line Quality
on 25-09-2020 11:12 AM
Please can you confirm if Monday afternoon is booked? In the meantime I have connected my old modem to see if dlm will change the profile using that,
