Thursday
I had to have a replacement modem sent to me, changing from a MT992 to a Sagemcom 4370 in early November. Before with the MT992 I was getting close to 300mbps down line speed, but now with the Sagemcom 4370 it has never gone above 230mbps. I have tried a couple of times turning off the modem for 35 minutes, but i'm still not getting the previous speeds.
The upload speed has been unaffected.
Any help appreciated.
yesterday
I'm sorry, I don't have an option to send an MT992
Thursday
What other options do I have?
Could you send a MT992?
Thursday
I can send another modem out just to make sure that the one you currently have isn't faulty, would you like me to arrange this?
Thursday
Yes, both.
Thursday
Ok thanks, are you using the cable supplied with the new modem?
Thursday
No I don't , I had to send it back.
Thursday
Do you still have the old modem? If you do could you try it again and check to see if the speed improves
Thursday
The Internet light on it did not light up, even though there was a stable connection.
Thursday
Hi coinup,
Could I just ask, why was you sent a replacement modem?
