on 30-05-2022 12:06 PM
Working from home I am becoming increasingly frustrated when taking incoming calls. I only experience the delay on incoming calls, and are generally 2-3secs. This causes miscommunication between myself and the customer I am trying to talk with.
My partner also experiences small delays when gaming in the evenings too, although we are never gaming and taking calls at the same time. I have checked our router settings and I can see both his console and my work laptop are on 5ghz, and our current download speed is 17.5mbs on a wireless connection, which my laptop is. Would it be improved if I had a wired connection?
Is there a reason for the delay that can be fixed?
on 30-05-2022 12:20 PM
Hi Lindseygregory87
Please can you add your name and TalkTalk landline number to your Community Profile.
on 30-05-2022 12:17 PM
Unfortunately i have not, I was previously informed that it would not make a difference. I Do not have another wire long enough to make the connection at this time. I will try to get one and test this.
on 30-05-2022 12:14 PM
Hi Lindseygregory87
Have you tested a wired connection to see how the connection compares?
