IP address blocked by spam checking sites
trickydicky
Message 6 of 6
I have been notified that my public IP address has been blocked by the spam checking sites, and this is causing side effects regarding email delivery and access to websites. This first happened last week and I resolved it by switching off my Router for a while and rebooting which then allocated a new (dynamic) IP address. I now find that the new IP address allocated is now on the Blocked list as well! Please advise how I can resolve this issue. I have performed a full virus scan on my laptop with no threats found. I am on faster Fibre with a Huwawei HG633 Router
5 REPLIES 5
Message 1 of 6
Hiya,
No problem, please let us know if there is anything else we can help with 🙂
Message 2 of 6
Thank you for letting me know - this is assuring and means I can stop worrying about that!
Message 3 of 6
a block on an IP address or it's listing on one of the many block lists will not be due to your own network or system.
Message 4 of 6
Thanks for the info Karl, but that is what I did last week, and although the new IP address worked OK for a few days, it seems that this IP is now blocked. Is there anything associated with my network that is causing this, or is it just the 'luck of the draw, and delays in the spam checking software gettng round to checking my IP? My anti-virus software says I am clean, but not sure if it picks up this kind of issue. I will reset my router again as advised, but I hope I won't be reporting this again next week!
Message 5 of 6
Like all ISP's we use dynamic IP addressing which means that from time to time your IP address will change.  It is also possible that at times you may get an IP that may have been compromised in the past by someone else.  This should not affect browsing however if you find that you have an IP that is blocked, you can either power off the router for a full 30 minutes to see if another IP is assigned, or contact the organisation that had listed your IP to request this is cleared.
