Increasingly Slow Speeds
MrPixelzz
Message 20 of 20
I am on Fibre65, i can apparently only get 1mbs on my line due to age and distance, at first it was a constant 1mb and i was dealing with the speed, However now i am only getting between 0.2 & 0.4mb download, and its becoming more and more frustrating waiting for web pages to load as if on dial up.
I have contacted TalkTalk previously, and nobody seems interested in helping me.
Just want to charge me £40 for an engineer to tell me nothing is wrong with my setup.
What are my options?
Brett Smith
19 REPLIES 19
Message 1 of 20
Thanks for the update. It can take up to 10 days for DLM to fully optimise the connection. If the stability/speed does drop again then please let us know and we can take another look.
MrPixelzz
Message 2 of 20
Afternoon,
Seems more stable than it has been. Still a few times when its drops low, but apart from that its better than it was.
Brett Smith
Message 3 of 20
Hi MrPixelzz
I've checked the connection stats and your line is showing in sync at 8.8mb.
How has the connection been over the weekend?
MrPixelzz
Message 4 of 20
Ok thanks guys, still plugged into test socket, and looks like things have improved slightly. Will check back in on Monday to see how its getting on
Brett Smith
Message 5 of 20
Hi MrPixelzz,
The line management system (DLM) has moved you to a faster profile over the last couple of days. Could you leave the router connected to the test socket over the weekend and we'll see if there's been any further improvement on Monday
Message 6 of 20
I have had my router plugged into the test socket for a few days now. There seems to be a slight improvement in the morning, getting 9mbps, but it drops through the day.
Below is showing the latest speeds:
The speed before the 7mbps, is 3mbps.
Brett Smith
Message 7 of 20
Message 8 of 20
I will try this when i get home this evening.
Brett Smith
Message 9 of 20
Thanks for confirming. Would it be possible to connect the microfilter, router and phone at the test socket for at least 48hrs so we can see if the speed improves in this set up please?
Message 10 of 20
Hi Michelle,
It does have a test socket, i believe i have the NTE5c from Openreach.
Brett Smith
Message 11 of 20
I've run a test on the line which hasn't detected a fault, however I can see that the sync speed has dropped. Just to confirm, does your main socket have a test socket?
Message 12 of 20
See below picture also, current speeds, initially started as 10mbs, but now only 2mbps.
Brett Smith
Message 13 of 20
Apologies, i have updated my account with Talk Talk phone number.
Brett Smith
Message 14 of 20
  • TalkTalk Telephone number
MrPixelzz
Message 15 of 20
Chris, all updated.
Brett Smith
Chris-TalkTalk
Message 16 of 20
Hi MrPixelzz,
  • Name
  • Telephone number
  • Alternative contact number
Message 17 of 20
So are these speeds at different times of the day or something, there is nothing to explain what you have just sent me? From the firmware version mentioned in device info I can tell that you have the Sagemcom Fast5364 Wi-Fi Hub, but your information doesn't actually tell me that.
MrPixelzz
Message 18 of 20
Hi Keith,
The router:
Device Info
N7193054N017089
FAST5364 3.00
SG4K10002816t
3.7.8
4d 14h27m59s
5C:B1:3E:B2:7A:12
Speed is showing as below, but im getting less than that.
Line 1
DownstreamUpstream
2695797
11373797
22.406.90
29.900.00
5.605.70
Mostly wireless connections, with one wired connection.
Brett Smith
Message 19 of 20
What make/model of TalkTalk router do you have? If you log into it, what speeds are measured by the router. If you have one of the two Wi-Fi hubs this is in the initial dashboard area.
How do your devices connect to the router, via wireless, wired (Ethernet) or a mixture of the two?
