on 23-02-2025 04:23 PM
I've noticed that my internet connection is dropping more frequently than usual. It seems to have coincided with neighbours getting full fibre but may be a coincidence (or a sinister push towards selling it to me). Can someone please check?
Jamie
on 17-03-2025 08:51 AM
It was stable for you at the test socket? (as well as the sync speed increasing)
It could be a fault with the faceplate.
on 17-03-2025 08:49 AM
Yeah, since Friday morning.
on 17-03-2025 08:30 AM
These don't appear to be profile changes completed by DLM.
It may be the faceplate. Is the faceplate still re connected?
on 17-03-2025 08:09 AM
My router says there were two disconnections on 15/03 - 22:03 and 22:46.
on 17-03-2025 07:54 AM
Morning @jamieburchell
The line test this morning is clear - No faults detected.
The sync speed has remained the same too. Has the connection been ok over the weekend?
on 14-03-2025 11:34 AM
That would be great, thanks. I suppose the only difference now is that the phone is unplugged from the router but I don't see why that would make a difference to be honest, it's been that way for years.
on 14-03-2025 10:57 AM
If you would like me to run one more line test on Monday, I can check just to make sure everything is still clear?
on 14-03-2025 10:44 AM
Great! I'm none the wiser as to what the original problem was then 😂
on 14-03-2025 10:31 AM
Oh good 🙂
Yes, line tests are fine , no faults detected.
14-03-2025 10:30 AM - edited 14-03-2025 10:30 AM
It's all fine. Is the line test still good?
on 14-03-2025 09:54 AM
I've checked the sync speed again, and the sync speed hasn't dropped.
Has the connection been ok for you?
on 13-03-2025 09:37 AM
Great, I will check in again with you tomorrow 🙂
on 13-03-2025 09:33 AM
on 13-03-2025 06:28 AM
I'm sorry for the delay.
I can see that the sync speed has remained at 38.3mb.
Please can you try re connecting the faceplate and I will check the speed again tomorrow.
on 12-03-2025 03:22 PM
Happy Wednesday!
Would you like me to try reattaching the faceplate since nothing has changed either way since our last contact?
Jamie
on 10-03-2025 02:38 PM
We can try re connecting the faceplate again on Wednesday. If the speed drops again then this would indicate a potential fault with the faceplate.
on 10-03-2025 02:29 PM
Assuming everything is OK after Wednesday, what's the next step? Reconnect the faceplate/get a new faceplate?
on 10-03-2025 02:19 PM
I think the re connection was when DLM changed the profile to increase the speed.
It's going in the right direction so I will check this again on Wednesday.
Thanks again.
Debbie 🙂
on 10-03-2025 01:52 PM
So it has! Looks like it reconnected at 1:33 this morning at what looks like normal sync speed.
Happy to leave it plugged in to the test socket for now.
on 10-03-2025 01:23 PM
The sync speed has started to increase, it's now at 38.3mb (It was 33.5mb when I last checked)
Would it be ok to leave the router in your current set up to see if DLM increases the speed any further?
