No internet connection
Busker jack
Message 3 of 3
For the previous several hours I have had no Internet connection, only a flashing red light, can anybody help please.
Busker jack
Message 1 of 3
Hi Busker jack
The line test has not detected any faults and your line is showing in sync and connected. Is this working ok now?
Skynet_TX
Message 2 of 3
Hi @Busker jack,
If you are still having issues it would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
