PROBLEMS WITH HUAWEI HG-633 ROUTER
Mugatu72
Visitor
Message 5 of 5
Having problems recently with Huawei HG-633 Router. Coverage seems to have weakened significantly in last year? Can’t get ant wi-fi coverage in the upstairs bedrooms, and the router is in the place/position it always has been? Also drops out quite a bit, and needs rebooting often!
Also, phone and iPad complain about weak security WPA/WPA2 (TKIP) is not considered secure? Sorry, not very techy… but is this down to the router being old tech?
4 REPLIES 4
Message 1 of 5
Hi @Mugatu72
Mugatu72
Visitor
Message 2 of 5
Excellent, sounds good 👌
Message 3 of 5
Hi Mugatu72,
Thanks for your post. We can send a replacement router (Wifi Hub) to see how this compares. Would this be ok?
Message 4 of 5
Thanks for starting your own topic. You should use WPA2 AES where possible. As I mentioned previously, the support team will pick this up when they are back online next week.
