Removing connection from Router
Weevie
Insightful One
Message 5 of 5
I need to remove access to an old phone from my router
How is this done ?
I can access the router (192.168.1.1) and see all of the different options (including Access Control) but when I select the item to remove - it only allows modification of connection - not complete removal....
4 REPLIES 4
Message 1 of 5
@Karl-TalkTalk  ok thanks
Message 2 of 5
I think it just lists devices that have been connected previously, I think the only way to reset this currently would be a factory reset.
Message 3 of 5
@Karl-TalkTalkI think so yes - but why can I not simply remove /delete it ?
something has changed / updated on the router
Message 4 of 5
Are you able to identify and block the mac address of the phone.
