Unable to connect to Xbox 360 wirelessly
Message 5 of 5
I am having trouble connecting to my xbox 360 wirelessly.
I have tired using an ethernet cable and the xbox 360 connects immediately.
However, if I try to use the wireless adapter the signal is found but unable to connect to the internet.
Is this a common problem? Is there a solution?
Kind regards
Tom
4 REPLIES 4
Message 1 of 5
Glad to hear you've managed to resolve the issue, thanks for letting us know 🙂
Message 2 of 5
Thanks Keith.
I solved the issue by doing a factory reset on the router.
Message 3 of 5
Hi Tom
Apologies for the delay.
Did you have a chance to have a look at Keith's post?
Message 4 of 5
Do you actually connect OK to the router, but can't access the internet? Are there any error messages & if so what are they exactly. With the XBox, if you can connect to the router, can you open a browser & get to the router's management system via:-
http://192.168.1.1
