on 24-03-2019 09:59 PM
My DSL connection speed varies a lot between 20mbps and 35mbps (Guaranteed speed is 58.1mbps) and I occasionally also have line drops. An engineer already came to visit (Last week) and since then the speeds are slightly higher but still not what they should be and the line drops still occur. I've also tried a replacement router which hasn't worked.
on 27-03-2019 06:41 AM
I can see the sync speed is lower than it should be and am detecting a possible issue with a copper joint so will need to pass this across for an engineer.
I'll drop you a pm with some details required.
on 26-03-2019 07:55 PM
I've updated my account with that information
on 25-03-2019 08:39 AM
Hi Hasaan668,
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
