Upgraded to Fibre 65 but no change in speeds
Veiled
Message 15 of 15
Hi there,
I have recently upgraded to Fibre 65 but I am seeing no difference in speeds when I do speedtest it is 38 Mbps.
This is what I am getting on Service Center;
Speed to your Router
Est. speed: 31 Mbps - 39 Mbps
Measured speed today: 38 Mbps
Is there anything you can help with to increase speed or would you suggest downgrading back to my old contract?
14 REPLIES 14
Message 1 of 15
Hi Veiled
Private Message now sent 🙂
You should see a notification in the top right corner of the Community Page.
Message 2 of 15
Hi Veiled
Apologies for the delay. I'm just getting your PM's enabled.
I will post back as soon as the Private Message has been sent.
Message 3 of 15
Thanks. Debbie, not sure where to check private messages as I couldn't find this in my profile.
Message 4 of 15
Hi Veiled
Message 5 of 15
Morning Debbie,
Yes please if it is going to solve the issue and wont interrupt me from working for too long lets do that.
Message 6 of 15
Good Morning Veiled
Thank you 🙂
I've completed another line test with the router at the test socket and this is still detecting the same fault.
The next step will be an engineer visit to the property, would you like me to arrange this?
Message 7 of 15
Hi Debbie, I am connected to the test socket now. Have done speed tests but it is still the same. I will leave it like this overnight so you can do testing on your side. Please let me know when you are done.
Message 8 of 15
Hi Veiled
Thank you. Would it be ok to leave the router at the test socket overnight so I can run a line test tomorrow morning?
Message 9 of 15
Hi Debbie,
I will try to do this in the evening when I get home and send a reply when it's ready.
Message 10 of 15
Hi Veiled
Would it be possible to connect the router at the test socket? We can then run another line test in this set up.
Message 11 of 15
Hi Debbie,
Thank you for your reply. I think my router is connected to the master socket I haven't touched it since the install. I am not using my landline to make phone calls but I have been experiencing sudden disconnection of broadband frequently.
Is there anything I can do from my side or would you advise an engineer visit?
Message 12 of 15
Hi Veiled
I've completed a line test which has detected a potential fault and Openreach are requesting that we arrange an engineer visit.
Is your router connected at the test socket? Are you experiencing any faults with the landline service when making calls?
Veiled
Message 13 of 15
Thanks for your quick reply Skynet. I will do as you suggest and update my details accordingly and hopefully someone from the team can advise further.
Skynet_TX
Message 14 of 15
Hi @Veiled,
If you are now on Fibre 65, but your estimated speeds are 31 to 39 then being on Fibre 65 is pointless, as Fibre 35 can provide speeds of up to 40.
The staff here will be able to check and confirm that it is indeed correct that your line can only support speeds of up to 39, if they confirm that is the case then you could contact the loyalty team to revert back to Fibre 35.
