Wifi Channels Changing Automatically
SamElo
Message 7 of 7
I have analysed the surrounding wifi networks, and picked the best channel to get the highest performance.
I've noticed however that they keep changing constantly despite setting them manually. This is terribly annoying and interrupts my work. What is the use of setting them manually if the router keeps changing them? How can I disable this very annoying option?
6 REPLIES 6
Message 1 of 7
Hi MihalyJ
Please can you create a new topic on the Community, we can then look into this for you.
Message 2 of 7
Can I ask you to turn this off for me please? I can't use AUTO channel, because all the time changes back to Channel 40.
Message 3 of 7
Hi SamElo
No problem 🙂
Message 4 of 7
Thank you Debbie 🙂
Message 5 of 7
Hi SamElo
Apologies for this.
The WIFI optimisation has now been switched off.
Gliwmaeden2
Message 6 of 7
Staff can switch off "Wifi optimisation" for you.
Please leave the router on, @SamElo, and they will let you know when it's been done.
There's nothing you can do about it at your end.
