Yet More Issues
on 17-09-2024 07:12 PM
Message 14 of 14
My connection has started dropping multiple times a day, usually in frenzied bursts where it will go on and off several times in the space of 5 minutes.
If it does manage to stay connected (or reconnect at all, as it has been off for quite a while at the time of writing) then I'm getting speeds of around 0.5mbps down.
The phone seems to work fine and there doesn't seem to be any noise on the line beyond the normal levels.
It has been doing this for the last two days and it is only three months since we last had an engineer out to fix it.
I've checked all of the cables and reset the router, even swapped several bits out to see if it helped, which it did not. It's currently connected directly to the test socket and that has made no difference to stability or speed. I even tried leaving the router off last night and putting it back on when I woke up but that made little to no difference.
Labels:
- Labels:
Connection
Speed
Stability
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
13 REPLIES 13
on 18-10-2024 07:04 AM
Message 1 of 14
How are you getting on?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-10-2024 10:50 AM
Message 2 of 14
I've logged this out to BT Openreach for a Non Appointed engineer - Non appointed means the engineer will be dispatched to look at the line without requiring an appointment be made with you to visit your property.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-10-2024 10:40 AM
Message 3 of 14
There is a dial tone but there's also a lot of noise on the line.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-10-2024 07:39 AM
Message 4 of 14
I'm sorry to hear this. I've re-run the line test now which has detected a potential voice fault. Do you also have no dial tone? As soon as we have confirmed this then we can raise this straight over to Openreach for investigation.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 12-10-2024 10:17 PM
Message 5 of 14
The connection dropped on Friday night at around 11pm down to 0.7mbps and has dropped a few more times during Saturday. It's currently at 2.0mbps and hasn't been back up to full speed since it went off on Friday.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 23-09-2024 06:40 AM
Message 6 of 14
Good morning,
Thank you for the update. If it does happen again when it rains then if possible please can you post back here straight away and we can re-run the line to see if it detects a fault when it's happening/raining.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-09-2024 02:10 PM
Message 7 of 14
It's been connected without issue for a little over 24 hours now.
I imagine the problems will crop up again when it rains but for now I guess it's fine.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 20-09-2024 06:34 AM
Message 8 of 14
How has your connection/speed been?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-09-2024 10:36 AM
Message 9 of 14
Good morning,
Thanks for confirming and we'll check back in with you tomorrow to see if the speeds have remained consistent.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-09-2024 10:00 AM
Message 10 of 14
It's all connected and the speed seems to be back to around normal but there were occasions in the last few days when it would go back up as well, only to drop back down 15 minutes later. So I'll hold off on the celebrations for now.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 19-09-2024 07:11 AM
Message 11 of 14
Thank you. Please post back here to confirm once this is set up and we'll check this again for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-09-2024 10:43 PM
Message 12 of 14
I do. I've been out all day but I'll set it up in the morning and let you know.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-09-2024 07:14 AM
Message 13 of 14
I'm sorry to hear this. I've run a line test now which is clear, however your connection looks very unstable. Do you have a different router that you could test with just so we can rule this out?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
