14-07-2024 05:10 PM - edited 14-07-2024 05:15 PM
Not happy with the speed i'm getting at B10 I have tried everthing on my side, from changing computer, laptop, mobile still the same speed at 55mb and 12mb upload.
with a new Internet cable RJ45 still same issue. Use to get 70mb and 18-20 upload speed. I am on Fibre 65
on 26-08-2024 08:29 AM
Hi @techmind
The line is showing in sync at just under 67mb.
Please can you power down the router for a full 30 minutes and then run another speed test?
on 25-08-2024 05:43 AM
@techmind, leave the phone and router plugged in at the test socket [so behind the faceplate]
until staff have time to test the line with this set up.
Set it up today and it will be checked either Monday or Tuesday [there's a Bank Holiday, so fewer staff].
I'll re-escalate this for their attention. Check back for following up during the week.
on 24-08-2024 09:21 PM
I have the NTE 5C MK 4 test socket and its working fine but still getting 35mb download and upload speed of 13mb upload.
Where it use to be 70mb download 18mb download.
on 23-07-2024 08:44 AM
on 17-07-2024 06:43 AM
Does your main socket have a test socket please? If it does then would it be possible to connect the microfilter, router and phone at the test socket so we can re-check the connection stats?
16-07-2024 07:01 PM - edited 16-07-2024 07:03 PM
Staff also need to know if you have a test socket, @techmind.
You need to read this article and identify which type matches yours:
https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432
The noise that might be on the line would while making calls. Is it crackling? It wouldn't be "outside".
on 16-07-2024 04:27 PM
I hear noise everyday outside and inside.
on 16-07-2024 03:31 PM
Please answer the questions so that staff are better able to follow up.
See @Anonymous's post prior to yours, from this morning.
on 16-07-2024 03:28 PM
Hi techmind,
We are waiting for a reply to the questions Michelle asked in her post this morning
on 16-07-2024 03:17 PM
any update on this?
on 16-07-2024 07:30 AM
Good morning,
Thank you. I've run a test on the line now which is clear, however I can see that the sync speed has been varying. Is there any noise on your voice service? Does the main socket have a test socket please?
15-07-2024 07:50 PM - edited 15-07-2024 07:51 PM
@techmind, the minimum guaranteed speed is a different figure from the expected download speed for the particular line. Different again from average advertised speeds for the package.
Upload speeds, however, cannot be guaranteed.
70Mbps is high for a Fibre65 line.
Staff will be back on here from the morning.
on 15-07-2024 05:50 PM
If I am geting a speed of 70MB and 17-20Mb upload before now they have said its guaranteed 58mb and 12 upload speed.
not happy because this has been changed.
on 15-07-2024 04:07 PM
ok I have updated this.
on 15-07-2024 08:29 AM
Hi techmind,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 15-07-2024 05:54 AM
Or maybe the old copper wires are deteriorating with age?, a dodgy corroding connection somewhere? or whatever. The Openreach DLM can/will adjust parameters to ensure stability in response to errors detected on the line, but TalkTalk cannot deliberately slow down your connection speed by a little bit the way you are describing. Has the speed dropped below the guaranteed minimum stated in your contract?
14-07-2024 05:39 PM - edited 14-07-2024 05:40 PM
speedthis is what i had last year. The speed has been reduced this year. Maybe to get more people to join them in our area lol
