on 11-01-2024 11:51 AM
Hello, I seem to have major dns problems, my laptop keeps disconnecting and saying failed to connect to dns, but also one of my Samsung Smart TV has done the same, I have used public dns settings which make it better but why shouldnt I be able to set to auto and it work?
on 05-02-2024 03:59 PM
OK, can you switch the router off and leave it off for at least 30 minutes, then switch back on and check to see if it's still there (please leave the powerline adapter unplugged while you do this)
on 05-02-2024 03:45 PM
I can confirm it is...
on 05-02-2024 03:42 PM
OK could you try rebooting the laptop and check if it's still there
on 05-02-2024 03:24 PM
Unplugged and no it doesnt go, still there...
on 05-02-2024 01:06 PM
Could you try switching the powerline extender off and check to see if the hidden network disappears (you may need to rescan)
on 05-02-2024 01:03 PM
I am using a powerline extender but this showed up before I used it
on 05-02-2024 01:00 PM
Are you using wifi extenders?
on 05-02-2024 12:57 PM
Sagecom
on 05-02-2024 12:56 PM
If you read this it seems to be part of the Sagecom Router?
My Sagemcom FAST 5364 Router seems to be broadcast... - TalkTalk Help & Support
on 05-02-2024 12:53 PM
I don't know, it looks as though the laptop is picking it up twice, once with the SSID and again as a hidden network. You could try rebooting the router and check to see if still shows up
on 05-02-2024 12:32 PM
Yes it will! that is strange why is it doing that?
on 05-02-2024 12:22 PM
OK thanks. If you enter you SSID will it let you connect?
on 05-02-2024 09:40 AM
Not without entering SSIDHidden
on 05-02-2024 09:34 AM
Thanks. Are you able to connect to it?
on 05-02-2024 08:53 AM
Hidden
My laptop shows it up as a netork....
on 05-02-2024 08:24 AM
Hi JaceyBoy,
Where are you seeing the hidden network?
on 03-02-2024 04:52 PM
For some reason I am showing a hidden network, I read somewhere that the Sagecom Router does this, is there anyway of hiding it?
on 31-01-2024 06:53 AM
Hi JaceyBoy,
No problem at all, just glad to hear that you got to the bottom of this.
on 30-01-2024 03:33 PM
Hi Chris,
Right I have got to the bottom of the problem, and it is down to the Blink Cameras I have, I think they have been hacked and were causing the network chaos, I have left it unplugged (sync unit) and the wifi has been absolutley fine for the past 24 hours, so I apologise it was nothing to do with the TalkTalk router......
