on 23-11-2023 02:40 PM
Can I upgrade my speed to full fibre without changing to new echo router ? My old router allows me to connect few devices by the wire where the new has only one wire socket.
on 24-11-2023 06:11 AM
Hi Lucas1,
As Keith says, your current router will be fine, just let us know if you need any further information
on 23-11-2023 03:12 PM
Then your current router would be fine, just connect the ONT to the red WAN port on the 5364.
on 23-11-2023 03:11 PM
Thanks. I assume that’s something to do with land line. I’m not using it for years anyway.
on 23-11-2023 03:07 PM
That will work fine, except that it does not support digital voice. You would need the hub 2 for that.
on 23-11-2023 03:06 PM
It is standard talktalk Wifi hub segamcom.
on 23-11-2023 02:53 PM
Depending on the fibre tier you subscribe to, you may be issued with the WFi Hub o Eero, but you do not have to use these. Whilst it is simpler to use the provide routers, some customers do use their own hardware. I myself am on full fibre, but use my own Asus router as it gives me more control over my internal connections.
on 23-11-2023 02:52 PM
What make/model of TalkTalk router do you currently have?
