Do I need new router ?
Lucas1
Message 9 of 9
Can I upgrade my speed to full fibre without changing to new echo router ? My old router allows me to connect few devices by the wire where the new has only one wire socket.
8 REPLIES 8
Message 1 of 9
Hi Lucas1,
As Keith says, your current router will be fine, just let us know if you need any further information
Message 2 of 9
Then your current router would be fine, just connect the ONT to the red WAN port on the 5364.
Message 3 of 9
Message 4 of 9
Thanks. I assume that’s something to do with land line. I’m not using it for years anyway.
Message 5 of 9
That will work fine, except that it does not support digital voice. You would need the hub 2 for that.
Message 6 of 9
It is standard talktalk Wifi hub segamcom.
Message 7 of 9
Depending on the fibre tier you subscribe to, you may be issued with the WFi Hub o Eero, but you do not have to use these. Whilst it is simpler to use the provide routers, some customers do use their own hardware.  I myself am on full fibre, but use my own Asus router as it gives me more control over my internal connections.
Message 8 of 9
What make/model of TalkTalk router do you currently have?
