on 15-02-2024 11:45 PM
Our new full fibre line was installed on the 31st of January and since then we’ve had nothing but headache, I have reset all my gadgets and appliances more times than I care to remember and even when they reconnect its not before long that they have issues. Our old line using the copper wiring didn’t have these problems and even after contacting TT and getting them to attempt to rectify the problem this only lasted a couple of hours, it’s now got to the point that I’ve payed extra money for data on my mobile phone plan just to use the internet, as there is none persistently at home… Need some help asap, as I’m not going to keep paying for a service I’m not receiving
on 21-02-2024 01:23 PM
The old hub was as you stated and the new device number is FAST 5464 - 2.T4, hope that’s helps
on 21-02-2024 01:12 PM
Hi @ang85
@Karl-TalkTalk has asked me to check for WiFi interference which I most certainly can & will do. However, before I do, please can you confirm that you used to have the Huawei DG8041W and now have the Sagemcom FAST5364, is this correct?
on 21-02-2024 12:33 PM
It could be a Wi-Fi interference issue if the lights remain solid on the router and on the ONT, so we can help to rule that out before looking towards an engineer.
@KeithFrench can you assist ang85 to check for Wi-Fi interference ?
on 21-02-2024 12:23 PM
So if the router is doing it job when working, could this be the wire coming into the house? as we’ve been through 2 new routers now with the same results
on 21-02-2024 12:18 PM
I've often found that some TV apps such as Netflix will buffer content so if a small drop occurs, they do keep playing.
Let me know if you want me to try the old hub? it looks more or less the same but without the gold inlay inside the front grille. At this point I’ll try anything to keep a stable connection
on 21-02-2024 12:16 PM
What’s strange is that the internet tv could be working, possibly this could be because it’s buffered enough to continue play, but the mobiles or other appliances will disconnect and then after some time or a reset reconnect… not sure what’s going on
on 21-02-2024 12:14 PM
Thanks for confirming the model.
on 21-02-2024 12:04 PM
Device Version:DG8041W-2.T5
on 21-02-2024 06:59 AM
I'm really sorry to hear this. What is the make and model of the original router that you were using please?
on 20-02-2024 06:38 PM
Hi there,
we received the router, but unfortunately we are having the same drops in WiFi as before, should I try the original router we had before the upgrade? Or do you think its the new cable/connection coming from street level as we had no issues before the upgrade
many thanks
on 19-02-2024 02:14 PM
Hi ang85
Have you received the router?
on 16-02-2024 12:23 PM
Hi ang85
I've requested that the router is sent, please allow 48-72hrs for this to arrive.
on 16-02-2024 12:06 PM
That would be great thank you
on 16-02-2024 11:02 AM
Ok thanks for confirming. If the lights are remaining consistent on the ONT box then this could be related to the router. Would you like us to send a replacement router for testing purposes to see how the connection compares and to rule this out?
on 16-02-2024 10:30 AM
just googled as I’m not home atm, it’s the greg WiFi hub as it doesn’t look like the eero
on 16-02-2024 10:23 AM
Hi there, ty for your quick response, I’m not sure on the hub as it was the one left by city fibre on installation, we have one thing wired which is the Hive heating, this seemed to loose connection too as it wouldn’t communicate sometimes with the app
on 16-02-2024 09:59 AM
Hi again,
Ok thanks for confirming. Do you have any devices connected wired? If so do they also drop connection at the same time? Are you using an eero or the wifi hub please?
on 16-02-2024 09:54 AM
The router normally doesn’t change from the normal white light and the box on the wall, if that’s what you’re referring to? Is normally just 4 green lights, I’ve reset both several times, but the connection is always short lived especially on our mobile phones, WiFi hoover, Ring doorbell, oddly enough the internet tv is the only thing that will maintain a stable connection for a longer period, but I’ve also had to reset that daily in order to get a connection in the first place. Please can you help?
on 16-02-2024 07:38 AM
I'm really sorry to hear this. Can I just confirm, do any of the lights change on the ONT when this happens?
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
