22-05-2024 03:49 PM - edited 22-05-2024 03:55 PM
Is there any chance someone in support could check my line at the moment. It seems to be dropping out and massive packet data loss!
Nothing has changed and it's been stable for weeks if not months.
Something isn't right?
There seems to be massive crackling on the line today and I've just run a connection test on the TT website and it says there is a problem -help!
TIA Steve
on 23-05-2024 09:30 AM
The faceplate is completely off.
on 23-05-2024 09:29 AM
Thank you. I've just re-run it again and it's showing the loop fault again. Is the faceplate also lifted away slightly to reveal the test socket?
on 23-05-2024 09:23 AM
Still nothing 👍
on 23-05-2024 09:22 AM
Ah ok thanks for confirming. I'll run one more test now. What is currently connected at the moment please?
23-05-2024 09:20 AM - edited 23-05-2024 09:22 AM
No, it was the same both tests without anything at all.
BTW There is only one test socket and I haven’t got a separate filter as the Master socket front has the separate broadband socket.
Does that mean I need a new Master Socket?
Steve
on 23-05-2024 09:18 AM
Hi Steve,
Apologies for the confusion, I though the previous test was with just the phone and router connected to the test socket?
on 23-05-2024 09:03 AM
Hmm, that’s great but the test you did just before the last one still showed a fault even though I had nothing connected?
Steve
on 23-05-2024 09:01 AM
Hi CaptainNemo
The line tests are now clear - no faults detected.
Is the noise still present if you connect just the phone and filter at the test socket?
on 23-05-2024 08:48 AM
Yes, go ahead. There has been a LOT of crackling on the phone line over the past while?
Steve
on 23-05-2024 08:35 AM
Thank you. It's still showing the same possible fault. Could we do one more test with all equipment removed from the line for 10 minutes?
on 23-05-2024 08:27 AM
Okay, I’ve taken the front plate off so there is nothing connected no phone no broadband so fire away to see if there’s any issue now!
on 23-05-2024 08:21 AM
OK, give me 10 minutes.
on 23-05-2024 08:20 AM
Hi Steve,
Would it be possible to connect the microfilter, router and phone (if you use one) at the test socket so we can re-run the line test again please?
on 23-05-2024 08:18 AM
Hi Michelle, thanks for getting back to me. My BT Master socket 5C does have a test socket. What would you like me to do?
Steve
on 23-05-2024 07:29 AM
Morning Steve,
I'm sorry to hear this. I've run a test on the line now which is detecting a loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Does your main socket have a test socket please?
