Monday
Our Sagemcom Fast5464-2.00 has started to reboot back to factory default several times recently. With todays ‘smart home’ this is very inconvenient as the many interconnected devices all rely on knowing the personal SSID & WiFi password that we have set.
It takes a while to reconfigure the router to our secure standards and find there is no way to convincingly store the config anymore? Why no ‘save’ option?
We particularly need to lock the 2.4Ghz to another channel due to interference from extremely noisy local EE & BT routers.
What does the hive think we can do about this?
Wednesday
Hi @Kahawi
Sorry for the delay, the router has now been dispatched yesterday, and is on the way. I'll send you a PM with the tracking info.
Monday
You're Welcome 🙂
Monday
Greatly appreciated Karl, excellent service from the TalkTalk team, will let you know progress.
Monday - last edited Monday
Thanks Keith, it seems a new router is already on its way, great service from the TalkTalk team.
It's a pity about optimisation, the default channels are permanently occupied by neighbouring properties and higher channels work best for our building layout, but each power-up reverts to an already very busy Ch1.
Monday
Hi Kahawi
I'll swap out the router and see if this helps - replacement on the way.
I can only assume that the router is faulty, I have never seen one do that. I have asked one of TalkTalk's support to pick your thread up and replace it for you. However, you cannot lock the router to any channel, as it is managed by WiFi Optimisation. It used to be possible for TalkTalk to disable this, but they are no longer allowed to do this.
Monday
Hi @Kahawi not sure about the persistent rebooting but sad to say the 2.4ghz is likely managed by the optimization function which may not be disabled.
