Slow broadband and poor wifi
jimmymumu
Super Duper Contributor
Message 15 of 15
Hi. My internet speeds have become unstable. At times I'm getting as low as 26mbps at others it goes to 51mbps. I ran the test through my account and it shows no connection problems but it seems to be up and down a lot. As for my wifi, it seems a bit intermittent too, losing connection with my Google Home and struggling to use my smart TV. Could someone check my connection please?
Thank you
14 REPLIES 14
Message 1 of 15
Hi @Windturbine
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
Windturbine
Message 2 of 15
I have similar issues, lose broadband during important work Teams meetings, have to switch to my phone mobile hotspot sometimes, also TV often unusable and at other times its impossible to use I player fast forward or rewind without skipping most of programme. Presume this is lack of bandwith related.
Are there TalkTalk staff on here? i need to speak to someone, i cant see any help contact phone number on this website, thanks for tips
Message 3 of 15
Thanks @Anonymous
@jimmymumu  Keith will send you a Private Message.
Message 4 of 15
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
jimmymumu
Message 5 of 15
Yes please. I'll message you my email. Thank you
Message 6 of 15
@jimmymumu
Do you want me to send you my guide?
Message 7 of 15
Hi jimmymumu
The WIFI optimisation has now been switched off.
@KeithFrench
jimmymumu
Message 8 of 15
Yes, please. I've no idea what it is, but if it settles my wifi down, I'd be more than happy. If it makes it worse would I be able to ask for it to be switched back on?
Message 9 of 15
When Wi-Fi Optimisation is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 10 of 15
Good morning,
Would you like us to switch the wifi optimisation off to see how your wireless connection compares?
jimmymumu
Message 11 of 15
My Router is the Sagemcom WiFi HUB and the light remains white and my Wired speed seems to have settled around 50mbps but WiFi is still hit and miss
Thank you
jimmymumu
Message 12 of 15
Hi. My PC is wired straight to the socket and mostly comes in at 50mbps but it has been dropping down to the mid-20s on occasion.
Besides my PC which is hardwired, my other items, TV, Alexa and Google Home are all wireless and running on the 5ghz band. The symptoms I'm getting are either slower speed or disconnections. My tv struggles to play YouTube at times and my Alexa struggles to connect
There has been no change in the home environment; it normally runs at less speed than my PC, but not by much. There are no solid walls in the house and nothing electrical has changed.
My PC speeds seem to have settled a little.
Message 13 of 15
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 14 of 15
Good morning,
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault and the sync speed looks consistent at the moment. Can I just confirm, is your TV connected wirelessly? If you run a wired speed test what speeds are you currently seeing please?
