on 27-11-2023 03:15 PM
I was upgraded to Full Fibre 65 last month and received a Hub2 to use with my landline. It's a Sagemcom FAST 5464-2T4 running SG4K100174 firmware. Ethernet outputs deliver a rock steady 75mb/s down and 19mb/s up, but WiFi speeds on all my devices are much slower, typically 20-30mb/s down on both wireless n 5GHz and wireless ac connections. Resetting the router raises my wireless speeds back to 70+ mb/s for a day or two, but then wireless speeds drop down again and the router needs to be reset again to restore performance. On Ookla speed tests the wireless speed starts initially at 70+, but very rapidly drops off as if a buffer is filling up in the router or the router can't maintain the throughput. This didn't happen with my previous Sagemcom Hub which gave a very steady 65mb/s on ethernet and WiFi with all my devices & hub in exactly the same locations. I am thinking the router is faulty or there is a bug in the firmware. Any thoughts?
on 28-11-2023 04:01 PM
Hi @rgbargey
If the new router does not resolve this, then the issue is probably Wi-Fi interference.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
on 27-11-2023 03:26 PM
No Problem 🙂
Very many thanks. I'll swap routers and report the outcome after a few days of monitoring.
on 27-11-2023 03:24 PM
I'll get a replacement Hub out to you and see if this helps.
