WIFI channels keep changing full fibre very slow speeds
Welshy_Pete
Message 5 of 5
Hello
I had the auto optimisation switched of originally for the standard broadband it made a big difference allowing me to choose the channels.
So 3 months ago I upgraded to full fibre 2.4ghz and 5g we use and the speeds and connections have gone worse. I checked and the channels are changing again and this is causing really slow speeds and connection problems.
Please can I request the auto optimisation to be switched off for my router so I can manually select the channels to get my full fibre back to speeds and connections?
Many thanks
Peter
4 REPLIES 4
Message 1 of 5
I've just replied to your other topic now 🙂
Message 2 of 5
Hello Debbie I'm trying to find the other place it was posted but cant find it.
There anybody able to direct me to the post?
Message 3 of 5
Hi Welshy_Pete
I have posted on your other topic on the Community.
Divsec
Message 4 of 5
Hi @Welshy_Pete your post has been escalated and you should hear soon. From recent posts it looks as though the community staff have lost the ability to do this but I'm sure they will do their best to assist.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
