on 21-02-2024 12:45 PM
Since installing full fibre, the router has been moved to a less central position in the house and the WiFi doesn't reach all the rooms. Thinking of getting a booster. How do I get the TalkTalk one? Not easy to work out how to do this on TalkTalk's website!
on 30-01-2025 06:55 AM
Hi @kt222
As advised, please can you create your own topic and we can look into this for you.
on 29-01-2025 10:37 PM
See above, @kt222, - you need to start your own thread.
on 29-01-2025 08:26 PM
honestly this new fibre is absolute rubbish..i've had the same problem as you ,im in a 3floor house .old Reuter was in middle floor never a problem the new one on bottom floor now top floor gets no service absultly awful,, don't know why they changed if they cant provide the same or better service
on 02-11-2024 01:19 PM
Hi @BANAKYN
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
When you do create your own thread, please state the make/model of router that you currently have & why you think you need a WiFi extender.
on 02-11-2024 12:11 PM
Hello, can i get a wifi extender
on 20-03-2024 03:30 PM
OK Charlotte, I've ordered them, they should be with you within a couple of working days
on 20-03-2024 02:55 PM
Hi Chris,
Yes it would be great if we could give those a try please. Many thanks,
Charlotte
on 20-03-2024 10:20 AM
Hi Charlotte,
I'm really sorry but unfortunately I can't order the booster for you as it isn't specified for your package. I can send wifi extenders if you want to give them a try?
on 19-03-2024 06:22 PM
Hi Debbie,
I didn't receive this Booster, but would still like to try one. I'm pretty sure I added the information you needed on my Community Profile, but is there anything else I need to do?
Thanks,
Charlotte
on 21-02-2024 01:33 PM
Hi Charlie_b
Please can you add your name and TalkTalk account number to your Community Profile, I can then send this out for you.
on 21-02-2024 01:28 PM
Yes, that would be great. Thank you.
on 21-02-2024 01:18 PM
Hi Charlie_b
I can send you a WIFI booster for testing to see how the connection compares, would you like me to arrange this?
on 21-02-2024 01:12 PM
Sorry, router not 'modem'
on 21-02-2024 01:11 PM
Hi Michelle
It looks like the Fibre Connection box. We were supplied with an Eero but the engineer could not use it because it needed more output sockets I think. We are therefore using the same modem we had before.
on 21-02-2024 01:01 PM
Hi Charlie,
Just to confirm, does it look like the below? The grandstream should be a digital voice adapter for VOIP.
Setting up your eero | Future Fibre | TalkTalk Help & Support
on 21-02-2024 12:56 PM
Hi Michelle, Thanks - we're using a wifi hub. It says 'Grand Stream' on it.
on 21-02-2024 12:50 PM
Hi Charlie,
Are you currently using a wifi hub or an eero please?
