Home Phone
Land line
newboy
Chat Champion
Message 28 of 28
Hi, I have tried to check on open case for landline. it says fixed on 4/11/2024.
Fault still same but I cannot run connection test as case is open?  which is correct . fault still exists, and cannot reach anyone in chat. Phone no use as I have hearing problems. Anyone assist. Thanks. (needed a rant)
27 REPLIES 27
Message 1 of 28
newboy
Chat Champion
Message 2 of 28
Hi Michelle,
thanks for that, fingers crossed.
Message 3 of 28
I'm sorry for the delay. I've booked the engineer visit for November 28 2024,AM (8-1) We'll check in with you after the visit to see how you're getting on.
newboy
Chat Champion
Message 4 of 28
HI Michele,
Not sure what you mean by time related, but yes I understand if fault is on my side, I will have to pay for engineer visit.
I need box and wiring checked.  Available all day next  Mon, Tues or Thursday.
thanks
Message 5 of 28
If the noise is still present at the test socket with 2 phones then we'll need to arrange another engineer visit. Please can you confirm acceptance of potential time related engineer charges and provide a few days availability AM and PM and we can book this in for you.
Message 6 of 28
Hello again,
I've re-checked and the planned engineering work is still open. I'll continue to monitor.
Message 7 of 28
I've just checked and it's still showing the planned engineering work ongoing so I will check this again this afternoon.
newboy
Chat Champion
Message 8 of 28
Thank you.
Message 9 of 28
Good afternoon,
Ok thank you for confirming. I've re-run the line test now which is clear, however I can see that there is currently planned maintenance work ongoing. As this may be affecting the line then I will check this again in the morning to see if this is resolved before we raise this back to Openreach.
newboy
Chat Champion
Message 10 of 28
Hi Michelle, yes the noise is still at test socket, he did not use his own equipment to test socket.  He did check green box in road and said he found two damage clips which he replaced.
Message 11 of 28
I'm sorry for the delay. Can I just confirm, was the engineer also able to replicate the noise when they tested with there own equipment? Is the noise still present at the test socket at the moment please?
newboy
Chat Champion
Message 12 of 28
Hi Chris, engineer came,  crackle still there, case has been left open.  my setup still not checked, box in house not been checked.
Message 13 of 28
newboy
Chat Champion
Message 14 of 28
Thanks Chris, will do.
Message 15 of 28
Hi newboy,
I've booked the first available appointment as requested - November 18 2024, AM - please let us know how you get on
newboy
Chat Champion
Message 16 of 28
Hi,  20th and 27th of this month, not available.
Message 17 of 28
Hi @newboy
Are there any specific days you aren't available for an engineer? I can then book the first available visit based upon your availability.
newboy
Chat Champion
Message 18 of 28
.Hi Debbie,
I am available most am, some pm this month.
Message 19 of 28
Morning newboy
I can arrange the Openreach engineer visit for you.
Please can you provide your availability for this visit AM and PM?
Can you also confirm potential Engineer charges
newboy
Chat Champion
Message 20 of 28
Hi Chris,
yes please. I cannot think  of what to try next, so need someone to look at my setup.
