Home Phone
Land line
newboy
Chat Champion
Message 56 of 56
Hi, I have tried to check on open case for landline. it says fixed on 4/11/2024.
Fault still same but I cannot run connection test as case is open?  which is correct . fault still exists, and cannot reach anyone in chat. Phone no use as I have hearing problems. Anyone assist. Thanks. (needed a rant)
55 REPLIES 55
Message 41 of 56
newboy
Chat Champion
Message 42 of 56
Thanks Chris, will do.
Message 43 of 56
Hi newboy,
I've booked the first available appointment as requested - November 18 2024, AM - please let us know how you get on
newboy
Chat Champion
Message 44 of 56
Hi,  20th and 27th of this month, not available.
Message 45 of 56
Hi @newboy
Are there any specific days you aren't available for an engineer? I can then book the first available visit based upon your availability.
newboy
Chat Champion
Message 46 of 56
.Hi Debbie,
I am available most am, some pm this month.
Message 47 of 56
Morning newboy
I can arrange the Openreach engineer visit for you.
Please can you provide your availability for this visit AM and PM?
Can you also confirm potential Engineer charges
newboy
Chat Champion
Message 48 of 56
Hi Chris,
yes please. I cannot think  of what to try next, so need someone to look at my setup.
Message 49 of 56
OK thanks. to investigate further we'll need to arrange an engineer visit. If you'd like us to do this please let me know and I'll confirm some details with you
newboy
Chat Champion
Message 50 of 56
Hi Chris,
 Yes tried in test socket.  I have two sockets.
thanks.
Message 51 of 56
Hi newboy,
Did you try with the telephone connected to the test socket (the socket under the master socket faceplate)?
How many telephone sockets do you have in your home?
newboy
Chat Champion
Message 52 of 56
Hi Karl,
I have tried an old corded phone I had ,same result. also tried in master socket,  slightly better but still crackly.
Message 53 of 56
OK, before we look to arrange an engineer, just a couple of quick questions.
Have you tested another handset to rule out a fault with this, or tested it at a friends or neighbours so you are sure this is working correctly ?
Have you tested directly at the master socket of 'Test Socket' if you have one ?
newboy
Chat Champion
Message 54 of 56
Hi Debbie,  Thanks for reply,
No, I do not have a no dial tone fault.  It is just very noisy,  crackles a lot.
I am hard of hearing as it is, this just makes it impossible.
Message 55 of 56
Hi @newboy
I'm really sorry about this.
The line tests are clear. Do you have a no dial tone fault?
